ECU compatibility BL-130 to BL-180 for XBL100
Hi Gents
i think i have problem with my ECU BL-130 on a early XBL100
would a BL-180 work instead of the BL-130 with a suitable conversion lead ?
If so what would be the connections be to the MPX connector ?
the latest XBL 100 comes with the newer ecu BL-180
regards
Neil
Note !
yes you can swap a BL-180 for an older BL-130 with an adapter lead !!
regards
Neil
Note !
My Feedback: (48)
Yes, it can work. My older M100XBL was converted to a BL-180 after crash damage.
Since the BL-180 has MR30 connectors you'll need the following:
https://www.xicoy.com/catalog/produc...roducts_id=897
https://www.xicoy.com/catalog/produc...roducts_id=766
