SMOKE SYSTEM SET-UP ??
My Feedback: (24)
RE: SMOKE SYSTEM SET-UP ??
ORIGINAL: scoeroo
Mr Merlin ,
What is the correct way to set up a smoke system on one of your turbines ???
What are the best fluids for good smoke ??
Thanks.
Mr Merlin ,
Thanks.
This is not really an engine clinic question as it does not relate to the Merlin operation. Smoke systems are an add on accessory for any turbine engine, not engine dependent. The correct setup would be indicated by the smoke systems manufacturer. I suggest you look at the Tamjets smoke system which can be seen [link=http://dreamworksrc.com/catalog/product_info.php?products_id=137]HERE[/link] for further details.
As for smoke fluid, there are a few commercially available smoke fluids (Super Dri to name one) as well as home brews. Suggest you use the search fuction to research some fluid recipes.
Todd
