Ryobi 31cc
My Feedback: (34)
Ryobi 31cc
Any thoughts out there about using this on a Balsa USA Citabria Pro?
Any advice?
I plan on recovering the entire plane which is set up now for a YS120 so it is a good time to make the conversion.
Just looking to get away from the glow fuel mess. I would assume I have to move the servos to the rear etc for cg purposes, and would re-inforce the firewall. I am also considering putting some more lumber in the rear?
Anyone taken on this project before? If so any pics?
Any advice?
My Feedback: (23)
Citabria Pro/Ryobi
It may work, but the Ryobi is a 4 lb engine and the magneto/flywheel may not clear the cowl. You'd have to get an aftermarket electronic ignition, like I used on my Dynaflite Chipmunk.
The Citabria Pro is a very light plane, probably 10-11 lbs ready to fly, with an appropriate engine. Why add 2 or 3 more pounds to it, plus added tail weight needed to balance, when you can use a 91 to 120 four cycle like it was designed for?
If you really want a gas engine, take a look at the RCS140, small light and easier to install.
My Feedback: (34)
Ryobi
Thank you for the reply, I have heard that the airframe is too light from another source as well. I wonder if the ryobi will work on a Northwest Technologies Corsair? I bought the engine so these are the two planes I have. I may have to consider buying another plane for the engine, but was hoping I would not have to.
Thanks!
Thanks!
ryobi
This engine is best suited for 1/4 scale cubs and Taylorcrafts, ecspecially if you still have the stock carb on it. Too heavy for your Citabria and not enough umph for a Corsair (pronounced CUSS-air). Works good in most Balsa USA big planes.
