how to wire up starter box?
Old 05-25-2003, 02:03 AM
civictypenos
Default how to wire up starter box?
i have a ofna starter box,it has 2 titan 550 motors in it with a 12 volt battery.the way it is wired up now has a + to one side of one motor,then the other wire on the motor jumps to the other motor and the - on the other motor goes to the - on the battery,is this right?i think thats its wired in series right?should i wire it so each motor goes to the battery?it does not seem to want to move my ntc3 very good with my jp engine
Old 05-25-2003, 04:44 AM
Unstable
you can rewire it to parallel (yes it is in series now) but you need to remember that you will be pulling alot more amps (4x) then you were before. if your batteries are not up to it then you will get smoke.
if you have the juice to pull it off then you can try it, if you have any doubt dont.
