interference
interference
getting interference with my servo's! can i stop this!!
i've got a storm... runnning Hi-tec 645 servo and sanwa reveiver... that might be why??
any ideas!"!
any ideas!"!
interference
Nothing wrong with the brand of reciever, however depending on what the truck is doing and how the servo's are acting, will depend if the rf filter on the reciever is going out! pleasegive me more info!
Bateries volts, nicads, nimh or freakin duraccell.
am or fm reciever
sawnya is airtronics, antenna filter is a comon problem!
more info thanks tom
am or fm reciever
interference
Inside your reciever...Every reciever there is a small ceramic filter if this cracks which 90% of reciever failures is this problem...If this cracks then your signal is intermittent through the antenna and down to the reciever...Thus during the time the signal is interupted your servos will search for a signal and thus causing jitters and bumps and crazy acting....The fix Send your reciever in for repair...The cost cheaper to buy a new reciever!!!!!
Tom
Tom
interference
The reason I asked about batteries is because some guys use store bought and don't realize those go dead...when batteries get weak the reciever also becomes weak....You are fine you have fully charged rechargables....
So are you fm or am..Have you preformed a range check? what is the distance of your range check? have you shortend or lenghtend your antenna?
Tom
Tom
interference
you can not fix it yourself....trust me! You have to open the reciever up! And if you are just looking to be looking Don't (if it aint broke don't f**k with it )
It is cheaper to spend the 49.99 and by a new reciever if you have a problem or do what I do Airtronics offers a two year warrenty send it to them and tell them it is failing range check and that you bought it last season...They will fix it for shipping cost!
Tom
Tom
