hummingbird problems
WI
well i jis gotta hummingbird yesterday and all it does is spin i got the gain all the way up and the tail goin as fast as it can but it still spins crazily, it goes so fast i circles its a blur, please help im anxiouse to get hovering!!!!
RE: hummingbird problems
Same problem here. The darn thing wont take off. Just spin on the ground like crazy...what the H.E. Double Hockey Sticks am I doing wrong????!!! Help would be greatly appreciated.
Have you checked the sense on your tail motor? If you turn the heli quickly counterclockwise by hand, for example, the tail motor should work against you and speed up.
Rob
Rob
Tail rotation will always be CCW viewed from the right side with the stock tail - but the most important thing is that it generates a force that counteracts the rotation of the heli when you turn the heli CCW. If that isn't happening, there's no way the heli will stop spinning.
Rob
Rob
WI
i figured it out on mine, the tail gear from the motor was slipping so i put a DROP of super glue on the hole in the middle of the gear and now it works awesome!
