Vt80 starter rpm failure message
My Feedback: (9)
3600 - 4000 on start up is about rite
Cool down is around 6000 rpm's
Can you here the starter disengage when error on screen appears ?
Was the turbine bench run before install ?
Is the starter starting in the correct direction ? I ask this as I was sold a new one that tried to start in the wrong direction
Hi the start does disengage and it goes the right way ,the turbine was fine had two flights and the third it wouldn't start charged the battery and just keep get the same message,it's bin fine for the last 21 hours
Maybe the starter motor is broken, or, by the cold, or oil the rotor doesn´t spin as free as always. Have you tried to raise " starter power at ignition" ? If this doesnt works, maybe the starter is defective
