stuttering kinda sound and help!!!
IL
so after i resealed the motor, waited 24 hours, put it in the truck, then ummm got it running, first wouldnt keep running, then got it to, messed with the high speed, and it still is makin a stuttering noise, its weird and if i pick it up and floor it, it shakes really bad (maybe i never realized it before), but i let go of the throttle it will close the carb, but it still stays kinda high and then stutters.....its not to rich...not to lean tried both ways......help!!! is it the clutch?? or should i get a new motor? and it also seems quiet and weird, i dont kno wat the problem is but the carb is closed so it still runnin but stutters like i see the gears shake back and forth.......i need to get this thing running right!
edit: well i reset the settings back to factory and seems to be runnin better, was runnin before (before i set back to factory) at 230 and now its at 210.....wierd but then again its cold out so its runnin alot better though. reseal i do believe helped alot........but now i get like a whining noise when it runs.....like when i give it gas.....maybe the diffs????
IL
RE: stuttering kinda sound and help!!!
like u can barely hear it cuz the exhaust but i hear like a high pitched noise when i give it enough throttle.....maybe i just never realized it
