G62 G38 G 26 sparkplugs? sameplug?
RE: G62 G38 G 26 sparkplugs? sameplug?
It would appear that the G62,G45 and G38 use the same plug , the Champion RCJ7Y (859 )
The G26 uses a different plug the RZ7C
Hope this helps
Hope this helps
IA
...and if you happen to have any of the above engines converted to electronic ignition, it may be yet another plug, such as a CM6...etc.
Chad
Chad
NC
Is there a rcj8y. I have a rc ignitions g62 convertion that broke a plug during a crash. All that is left is j8y on the plug. Do you have to use a different plug on converted engines or can you use a rcj7y?
