Klett Hinges in 35%???
My Feedback: (25)
AR
Traditionally being a Robart man, when I got my new 35% ARF and found it had Klett hinges I became a little concerned. I am considering adding some Robarts to the ends of the surfaces.
Is anyone else using Klett or Sig Brand XX hinges in 35% + planes? How many per surface (my main concern being rudder)?
The model is a 35% Extra that will weigh 25lbs and be powered with a DA-100 to do 3D and IMAC (to give you an idea of control surface loading).
IN
RE: Klett Hinges in 35%???
I really like the Klett hinges - put in with slow set epoxy. I use a feeler gage to butter the slot with epoxy. I've never been able to pull one out. I haven't used them on a 35% plane (ARFs already drilled for Robart hinge points), but I wouldn't hesitate to use them.
I have Klett hinges in my RadioCraft 35% Extra and have not had one fail yet after over one year of flying (IMAC and 3D) Here is how many on each surface:
Ailerons-8 ea.
Elevator-6 ea.
Rudder-5
Ailerons-8 ea.
Elevator-6 ea.
Rudder-5
