Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
KONDOR XL 20-37 motor max cell count
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 06-20-2023, 05:28 PM
rcfs
Default KONDOR XL 20-37 motor max cell count
Does anyone know how many lipo cells a KONDOR XL 20-37 motor can handle safely? Thanks
Old 06-29-2023, 12:28 PM
ron_van_sommeren
ron_van_sommeren's Avatar
Motors, unlike ESCs!, can handle any voltage in RC land, as long as current & power drawn and rpm don't get too high.
The wire insulation/laquer/resin can withstand several hundred volt.
So the max.voltage depends on the prop: the higher the prop load and/or on Kv (→higher current), the lower the max. operating voltage (→lower current).
Therefore: what prop would you want to use, what velocity konstant Kv? With those numbers you can calculate rpm, current and power drawn.
Using e.g.
www.ecalc.ch
www.rcgroups.com/forums/showthread.php?736782-Scorpion-Calculator
Voltage/prop combination tables are merely suggestions.
To keep current and power drawn in bounds, the highest voltages should go with the low-load prop, the high-load props go with the low voltage.
All this because current drawn goes up with pitch, voltage² Kv³ and diameter⁴
Although velocity_konstant_Kv has a massively disprportional effect on current (squared) and power (cubed) drawn, Kv, measured/expressed in rpm/volt, says nothing about a motor's max. current and max.power ratings.
Both the motor in your electric toothbrush and the motor in a 1:1 train can have th same Kv.
A very long clearance sale, originally 200+$, versatile, high quality, now literally peanuts:
Hyperion Emeter II wattmeter with local&remote logging, optical&electrical rpm meters, servo tester - RCG
Without a watt/volt/current/multi-meter you are in the dark.
Until something starts to glow
Old 06-30-2023, 10:26 AM
ron_van_sommeren
Using e.g.
www.ecalc.ch
Prettig weekend Ron
• Without a watt-meter you're in the dark ... until something starts to glow •
E-flight calculatorswatt-metersdiy motor tips&tricksCumulus MFC
