How to repair a foam wing?
Old 05-02-2010, 04:52 PM
surf
Default How to repair a foam wing?
What is the best way to repair this balsa sheeted foam wing? The prop did not hit anything but foam and sheeting. The foam has been compressed and leaves a hole when the prop is removed. Should I cut a square out of the wing and replace with foam and sheeting or just repair with sheeting leaving a hole. Thanks.
Old 05-02-2010, 06:17 PM
sensei
sensei's Avatar
Default RE: How to repair a foam wing?
Just cut the covering back about 1.5" all around on both sides, then cut the sheeting to a clean hole and replace the sheeting. Thats all there is to it...
Bob
Old 05-02-2010, 06:39 PM
surf
So no foam replacement just the sheeting? Thanks.
Old 05-02-2010, 07:42 PM
Rick75
Rick75's Avatar
If you want, just put some gorilla glue in the hole let expand, after the glue is cured trim the foam and sheet the area.
Just my 0.02
Old 05-02-2010, 09:57 PM
sensei
sensei's Avatar
ORIGINAL: surf
The damage is really in a non stress area, you can fill it if you want but it won't buy you anything.
Bob
Old 05-03-2010, 05:22 AM
surf
thanks
