used OS 61FX F/S
used OS 61FX F/S
I have this OS 61 FX for sale,
I am the original owner, this engine has 6.5 gallons run threw it, I replaced the bearings, the Piston and Liner are in very-very good shape, the compression is very good, the engine was never run lean, after replacing the bearings the new front bearing started to leak a little bit after I ran 2 tanks ON the bench, at that I decided to just sell it and buy a 4St,,
if some one buys it and replaces the front bearing I should make them a good engine, no muffler, Needle Valve's O-rings should be replaced,, $55 shipped inside the USA
Jim
Jim
