Titan ZG 38 SC
Titan ZG 38 SC
Hi Guys ! I was breaking in my Titan ZG 38 SC equipped with a belt driven reduction gear factory installed by Toni Clark swinging a 32X18 prop .
Everything was great and i burned allready 4 liters of gaz in it . Until yesterday one of the belt broke and i noticed some cracks in the second belt . Does this happens often ??? What could be the reason ??? I did not alter the factory set belt tension . The only thing that happened is that when i was installing the fuel feeding tubing in the carburator inlet , few drops falled on the belt . Could this be the cause ???
I would highly appreciate any feed back ' cause this is my first gaz engine equipped with a belt driven reduction gear .
Thanks for any help
Thanks for any help
