HL Battery question
ON, CANADA
HL Battery question
hey guys
I was looking into getting some better batteries for my HL tanks but im not 100% sure if the batteries and charger I want are compatiable with one and another, heres the batteries and charger I want
Battery
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXAFD2&P=7[/link]
Charger
[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEHB6&P=[/link]
Like I was saying I think they would work because the packs are 6 cell and it syas that it charges 6 cell packs, also would this cahrger be able to charge the stock battery packs that come from MATO with the tanks
Thanks for any help you guys can lend, I would have asked this at the battery forum but wanted to check with the tank guys first [8D]
Battery
Charger
My Feedback: (24)
RE: HL Battery question
Yes, that charger will charge the DuraTrax battery pack and the stock packs. As given in the specs, it will charge any 6-7 cell NiCd and NiMH battery pack. However, often you get what you pay for. The charger you listed can only be connected to a 12V battery, and you can't use it at home without a power supply. For a little more money, get something like this, which is an excellent charger: [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXUF45&P=0]DuraTrax IntelliPeak AC/DC Charger[/link]
ON, CANADA
wow, I didnt know that thanks Rich so the charger I listed cant be plugged into a household outlet? I will look into the one you listed
cheers again for the help
Just be careful though on the size of the battery pack. I have batteries for my RC cars and they don't fit the heng long tank battery compartment, it is slightly longer. Mind you, my batteries are NiMh.
The old NiCads that I have still fit.
ON, CANADA
plus I just realised that the battery I listed was NI-CAd and the tanks are NI-MH , silly me
Jeremy
I will continue to search around and read
Jeremy
My Feedback: (24)
You can still use a Ni-Cad battery pack. There is nothing wrong with that.
Yes, do be careful when buying another battery pack for your tank and double check its length. You want the battery pack to be less than 5-1/4" (133mm). Otherwise, the battery pack won't fit HL battery box.
My Feedback: (24)
Here is a picture of the battery packs I've collected, arranged from shortest to longest. The stock Ni-Cad pack is 5-1/8" long. The next one up is a McNair 3200 mAh NiMH pack at 5-1/4" long, and it fits snuggly into the HL battery box. The 3300 mAh pack next to it had to be forced in to fit. The other three do not fit.
Do the GP 3300 packs fit alright in the HL battery compartment? I presume the HL battery compartment is the same size throughout the lineup. But Richard L. raises a serious issue about subtle differences in various 7.2V packs, all purported to be of "standard" size.
Either we have to be wary of slight size differences in battery packs or perhaps we can increase the length of the battery compartment (to 1" longer or so) with sheet styrene and a little Dremel work.
Maybe it might serve well to start a battery thread where the different brand's sizes are noted as well as how well they fit into the HL tanks........
-Harq
-Harq
ORIGINAL: shenlonco
the radio shack GP cells are 3300 and they are standard size packs.
Shenlonco:
Thanks for the heads-up on the Super Brain charger! That looks like a great value and look at all the features/functions it has. Gonna have to look into that one.
Nice.
-Harq
Nice.
-Harq
My Feedback: (24)
ORIGINAL: shenlonco
My Feedback: (24)
ORIGINAL: Harquebus
I have this super brain959 and also a duratrax ice and a duratrax piranha and a super brain 977 and the 959 never over heats a battery and you can set the peak voltage to what you want so it will never over charge only if you set the MV setting really high...and that would be from your fault.
Also MRC has it's own patented micropeak tecnology it's supposed to be better than zero delta peak.
heres my radio shack battery are you sure you got the one with the GP cells?
mine is just a hair longer than the stock tank 2000 batery it's almost the same exact size?
