TRX 3.3 Tuning / running problems
Righto... well i know i saw a post in here about this but i cant find it anywhere. I've had a bugger of a time tuning my engine to idle and run like it did when i 1st got it. I remember seeing a post about the bearings in the motor and i may just have the same problem but I'm not sure. I noticed an excess of fuel coming out near the low speed needle when i held my finger over the exhaust. It was spitting out actually.... The car will fire up... but will not idle for long and when it does start to actually run for more than a few seconds it idle is so high the car just goes without me applying any throttle. When i do give it the gas it runs for a bit then sputters like its being flooded and then dies. Lots of hesitation when i give it full throttle.
It's been pretty frustrating to say the least... It seems like the more i run this thing the worse it gets for reliability. I'd be happy to put a more reliable motor in it if it's a 3.3 problem however i'd don't mind trying to fix it if possible.
Thanks again.
-Deano
Thanks again.
-Deano
RE: TRX 3.3 Tuning / running problems
Well, it is quite possible it COULD and i mean COULD be the bearings that are on their way out.....however; first i would try richening the low speed needle to try and bring the idle down a bit; if after u have done that, I might want to consider tearing that sucker apart and examining the internals to see if anything looks out of place...
Well before u go bothering to tear it apart, I would first try richening the low speed needle to see if it brings the idle down any. Then AFTER doing that IF it doesnt come down, then go from there....
Ok... i've finally figured out my tuning for the most part... i don't think my bearings are wrecked yet however... and heres the kicker. I cannot tune with my highspeed needle. If i run with it all the way closed it cuts out at full throttle. If I open it fuel begins to spill out everywhere. So i'm wondering. IS the brass peice that is connected to the carb supposed to move or is it supposed to be stationary. The reason i ask is the whole needle moves not just the black part where you can either use a screwdriver or fingers.
I can tune it to run right but there is fuel spilling out along the chassis and it didn't used to do this before....
Thanks again from a newb.
OH
yep, your HSN MIGHT be stripped... you can get a replacement, OR you can get a whole new carb... HSN being about $13, new carb being about $47...
ORIGINAL: TMaxxDriver
