Transferring laser pattern to plywood
WA
Hello everyone,
I've read back through a bunch of posts about transferring laser printed tracings to wood, and it seems the most popular way is with heat via an iron.
I've tried my sealing iron set to high as well as "borrowing" the wife's iron set to as hot as it would go, and I can barely get a faint transfer. I've heated it so hot that it started to warp the plywood, but could not get the paper to start turning brown as one post said.
I know there you can use transfer paper, but I'm trying to do something 41 inches long, so transfer paper isn't an option.
Any hints or ideas??
Thanks!!
Thanks!!
My Feedback: (-1)
I do as food stick and just use spray mount glue and glue the sheet to the wood,cut proud of the line then sand to the line itself.
I have heard of laying the ink side of the printed paper onto the wood and rubbing it down with acetone to transfer the ink. Never tried it but read about it here on RCU.
WA
Thanks everyone.
I ended up spraying some adhesive to the ply, putting the pattern down and cutting it out. Then traced around it with a fine pencil, pulled the paper off and cut it out.
Worked pretty well, but time consuming.
I have most of the lite ply parts in cadd now for laser cutting, but wanted to make a test run before spending the money on laser cutting.
I have a few spots to touch up to make sure it all goes together.
Next is laying out all the balsa parts and doing it all again.
