Is this all in the car
Is that ALL of the parts to a 3 Evo and if I where to build this from the ground up what other manufacturers car parts may I use for this?
15101 1 NITRO STAR T-15 ENGINE with PULLSTART $110.00
3797 2 SPLIT 6 WHEEL 26mm CHROME $7.00
4790 2 X-PATTERN RADIAL TIRE 26mm D-COMPOUND $11.00
6122 10 BODY PIN (MEDIUM/10pcs) $2.00
6154 10 NYLON STRAP (3.5x150mm/BLACK/10pcs) $2.00
6163 1 SERVO TAPE 20x100mm (5pcs) $4.00
6274 1 PRECUT FOAM BUMPER GRAY (RS4) $5.00
6807 2 SHOCK SHAFT 3x31mm (2pcs) $3.00
6816 6 SILICONE O-RING S10 (6pcs) $2.00
6819 5 SILICONE O-RING P-3 (RED/5pcs) $1.50
6836 2 SHOCK SPRINGS 13x29x1.55mm (BLACK) $4.50
50474 1 SILICONE TUBE 2x5x300mm $6.00
72001 2 PILOT SHAFT 4x30mm(2pcs) $4.00
72102 2 SHOCK CAP 12xM13x0.8mm (2 pcs/ PURPLE/ GROOVED) $4.00
72107 2 CUP JOINT 5x10x16mm (2pcs) $7.00
72108 1 CUP JOINT 5x10x16mm (1pc) $3.00
72110 2 SILICONE EXHAUST COUPLING (PURPLE/2pcs) $5.00
72140 1 AIR CLEANER 30mm $5.00
72144 1 LINKAGE SET $4.00
72148 1 BRAKE CAM SHAFT/PLATE SET $5.00
72157 1 ARM BRACE SET $2.00
72161 1 GEAR SHAFT 5x55mm (NITRO 2 SPEED) $5.00
73913 1 MAIN CHASSIS 2.5mm (6065 ALUMINUM/PURPLE) $30.00
76817 1 SPUR GEAR 47 TOOTH (1M) (NITRO 2 SPEED) $3.00
76822 1 SPUR GEAR 52 TOOTH WITH COLLAR SET (1M) $4.00
76843 1 SPUR GEAR 43 TOOTH (1M) (2 SPEED/NITRO 3) $3.00
76978 1 ALUMINUM THREADED PINION GEAR 18Tx12mm (1M)? $5.00
76982 1 ALUMINUM THREADED PINION GEAR 22Tx12mm (1M) $5.00
85029 1 RADIO TRAY SET $7.00
85030 1 SUSPENSION ARM SET $5.00
85031 1 SHOCK TOWER/ BUMPER SET $7.00
85032 1 BODY POST/ LINK SET $4.00
85033 1 SUPPORT SET $4.00
85036 1 GEARBOX SET $6.00
85037 1 REAR HUB SET (2 DEGREE/ 1 DEGREE) $5.00
85038 1 FRONT UPRIGHT SET (8 DEGREE/ 10 DEGREE) $5.00
85039 1 SERVO HORN (for SLIDE CARB./NITRO 3/NITRO MT/SUPER NITRO RALLY) $3.00
86014 1 GEAR DIFF BEVEL GEARS (13T and 10T) $7.00
86016 1 GEAR DIFF O-RING SET $2.00
86021 1 FLYWHEEL (with COLLET and PINS) $5.00
86022 1 COLLET 6x10mm $2.00
86023 1 CENTER DOGBONE 6x60mm $5.00
86036 2 DOGBONE 6x52mm (2pcs) $6.00
86037 1 ALUMINUM EXHAUST HEADER (BLACK) $14.00
86039 1 THREADED 2 SPEED CLUTCH BELL 12mm (NITRO 3 2 SPEED) $9.00
86050 1 2 SPEED MAINTENANCE KIT $5.00
87021 1 FUEL TANK with PRIMER (75cc) $11.00
87023 1 GEAR DIFF ADJUSTMENT SPRING $3.00
87028 1 TEFLON CLUTCH SHOE AND SPRING SET $6.00
93317 2 TURNBUCKLE 4-40x34mm (2pcs) $3.00
A249 4 BALL M2x3.8x4.5mm (4pcs) $5.00
A280 2 FLANGE SHAFT SET 3x25mm/A284 3x30mm $5.00
A281 2 FLANGE SHAFT SET 3x36mm/A282 3x42mm $5.00
A396 1 SERVO SAVER SET $5.00
A431 1 DIFF CASE $5.00
A471 2 SHOCK PARTS SET $7.00
A540 2 HPI SPORTS SHOCK BODY (45-56mm) (2pcs) $3.50
A556 2 AXLE 5x32mm (FRONT/2pcs) $6.50
A557 2 AXLE 5x38mm (REAR/2pcs) $7.70
A558 2 DIFFERENTIAL SHAFT (2pcs) $5.00
A559 1 GEAR SHAFT 5x37mm (1pc) $5.00
A783 4 BALL 4.7x14mm (PURPLE ANODIZED) $4.00
A805 1 PILOT SHAFT M5 $3.50
A838 4 FLANGE PIPE 3x4.5x5.5mm $3.50
A855 1 DIFF FINAL GEAR SET (P1x38T/P1x13T) $6.00
A868 1 TUNED PIPE (COMPOSITE NYLON) $10.00
A875 5 EXHAUST GASKET $2.50
A880 1 CLUTCH BELL FOR NITRO RS4 2 SPEED $20.00
A881 1 CLUTCH HOLDER FOR NITRO RS4 2 SPEED $12.00
A882 1 HEAVY-DUTY 1ST GEAR ADAPTER (PURPLE/NITRO 2 SPEED) $19.00
A896 1 THROTTLE LINKAGE SET $3.00
B021 2 BALL BEARING 5x10x4mm (2pcs) $15.00
B022 2 BALL BEARING 5x11x4mm (2pcs) $14.00
B030 2 BALL BEARING 10x15x4mm (2pcs) $15.00
Z125 14 BALL CUP (14pcs) $5.00
Z136 4 BALL END 4-40 (BLACK/4pcs) $3.00
Z150 1 ANTENNA PIPE SET $1.00
Z164 1 HEAVY WEIGHT GREASE (#30000/GEAR DIFF) $3.00
Z170 1 SILICONE SHOCK OIL #300 $3.50
Z224 10 WASHER M3x8mm (10pcs) $1.00
Z238 4 C CLIP 13mm (4pcs) $2.00
Z242 20 E CLIP E2mm (20pcs) $1.00
Z251 10 SPRING PIN 1.5x8mm (10pcs) $1.50
Z264 10 PIN 2x10mm SILVER (10pcs) $1.50
Z282 4 STEP SCREW M3x14mm (4pcs) $2.00
Z509 6 BUTTON HEAD SCREW M3x30mm (6pcs) $2.00
Z517 10 BINDER HEAD SCREW M3x8mm (10 pcs) $1.50
Z526 6 FLAT HEAD SCREW M3x8mm (6pcs) $1.00
Z527 6 FLAT HEAD SCREW M3x10mm (6pcs) $2.00
Z543 6 CAP HEAD SCREW M3x10mm (6pcs) $1.50
Z561 6 TP. FLANGED SCREW M3x10mm (6pcs) $2.00
Z567 10 TP. BINDER HEAD SCREW M3x10mm (10 pcs) $1.00
Z568 10 TP. BINDER HEAD SCREW M3x12mm (10 pcs) $1.00
Z569 10 TP. BINDER HEAD SCREW M3x15mm (10pcs) $1.00
Z578 10 TP. FLAT HEAD SCREW M3x12mm (10pcs) $1.00
Z581 10 TP. FLAT HEAD SCREW M3x18mm (10pcs) $1.00
Z593 4 SCREW SHAFT 3x27mm (4pcs) $2.50
Z599 4 SCREW SHAFT 3x40mm (4pcs) $2.50
Z653 6 NUT M3 (6pcs) $1.00
Z662 4 LOCK NUT M2 (4pcs) $4.00
Z684 4 FLANGED LOCK NUT M4 (4pcs) $2.50
Z694 10 WASHER M5x10x0.5mm SILVER (10pcs) $1.00
Z699 6 WASHER 7x12x0.8mm (6pcs/BLACK) $2.00
Z721 4 SET SCREW M4x4mm (4pcs) $2.00
Z903 1 ALLEN WRENCH 2.5mm $1.00
Z904 1 ALLEN WRENCH 2.0mm $1.00
Z950 1 CROSS WRENCH (SMALL) $2.00
Z960 1 TURNBUCKLE WRENCH $2.00
Set Parts (Spare parts)
Part# Qty. Description Price
86038 1 2 SPEED TRANSMISSION $70.00
A770 2 HPI SPORT SHOCK SET 45-56 SET
RE: Is this all in the car
See I wanna make a car even though I am a noob I like the risk. and I really want to make it all aluminum but I can't seem to get anyhelp around here! Please Help I am begging you I really want to get into this awsome hobby but It seems that I can't! maybe if you guys can help me out then I can. All I have been asking is, is there anywhere that will tell me about all of the parts and where they go (preferably a picture) and a good website that allows me to buy the parts that are colored (anno.).
MA
Thank you for the help, sorry I was mad a post before but I have been asking this question for about 2 days with minimal help and for the people that has/have help me Thank you very much, but I cannot name all of those parts as I am just getting into the sport.
