Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Does this Piston/Sleeve Look Trashed to You?
Old 10-23-2003, 04:40 PM
COLE
Default Does this Piston/Sleeve Look Trashed to You?
This is an OS .61SXHWC recently pulled from an ergo 60 helicopter. After running like a sewing machine for nearly two years, the motor is starting to exhibit some reliability problems. I pulled the motor and noticed the piston looks a little burnt and scored. What do ya' think?
OS61SXHWC
WILDCAT 30%
OS #8
HATORI MUFFLER
ID:	69578   Click image for larger version
ID:	69579   Click image for larger version
Old 10-23-2003, 05:43 PM
ChuckAuger
My Feedback: (12)
Default RE: Does this Piston/Sleeve Look Trashed to You?
It's ringed, right?? I don't think that looks bad unless the ring is shot..no pics of the ring, but a pic of the ring won't tell much (unless it's missing or something).
How's the compression?? Won't be too high on a ringed engine, but it shouldn't just spin right on around, ought to have some compression.
How do the bearings feel?? Is it silky smooth when you turn it over, or a little gritty feeling??
I'd suspect the ring or bearings...that piston doesn't look all that bad IMHO.
Old 10-23-2003, 06:43 PM
maxtenet
How long since last run? Could just be a stuck ring.
Max
Old 10-23-2003, 06:54 PM
COLE
Yes, this is a ringed engine and as far as I can tell by looking in the exhaust port, the ring is intact. The bearings feel great. If anything a little syrupy. About the compression, When turning the motor over by hand relatively quickly, it feels like it has good compression. However, when you turn the motor over slowly or pause slightly during the compression stroke, you can feel the chamber leaking/losing compression. If you turn the motor over slow enough, it will cycle completely with minimal resistance/compression. The motor was inactive for about two months prior to this week.
Thanks for the help,
Michael
Old 10-23-2003, 08:08 PM
Flypaper 2
Sounds about normal for a ringed engine. Taking the head off and looking at the cyl will tell you much more. Check for blue sections and score marks. Fine lines are OK but deep score marks are a no no.
Old 10-24-2003, 01:49 AM
Flyboy Dave
My Feedback: (21)
Flyboy Dave's Avatar
Looks good to me....you can remove the head, and run
some 320 paper with your finger on the cylinder wall to
de-glaze it....this will reseat the ring, and restore some
lost compression.
Old 10-24-2003, 09:42 AM
DMyer
I would suspect a fuel quality problem(is it fresh) or a fuel delivery problem(sucking extra air somewhere). I find that even fairly old & worn engines will run quite well if the fuel, and fuel supply and carb adjustment are good... even if power is down a bit. Your piston just looks like it is stained(do you use any caster oil).... not unusual at all. A good cleaning may be in order especially if there is any sludge burnt onto the ring groove causing it to bind and not seal correctly. Good luck!
Dan
