HELP!!!! saito 91 low-speed needle setting
My Feedback: (32)
I just took it out the box and was fiddling with it not knowing where the low speed needle was located. I saw a little screw in the center of the arm, which i thought that was to remove the arm. Well guess what i tried to unscrew it until i finally noticed that it was the low speed needle[] Now i need to know how many turns out do i need to unscrewn the little screw for breaking the motor. I know in the instructions, it says "Do not adjust the low speed needle". If there is somebody out there that can help me out and check it out on your saito i would really appreciate it. Thanks a bunch
Santi
Santi
My Feedback: (32)
RE: HELP!!!! saito 91 low-speed needle setting
Thanks guys. Hey Joebob How did you mount the throttle arm on your ucd46 Im in the process now and would like to see how you did it. Post a pic if you can.
Santi
Santi
