Range-testing with DA50
Old 04-21-2004, 08:47 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Default Range-testing with DA50
Hi,
I wonder if it is necessary to thruttle up the engine (middle or high RPMs) during the test. If there are interferences, will it only show up during middle/high RPMs, but not during idle?
Thanks --NonstopRC
Old 04-22-2004, 06:10 AM
pettit
My Feedback: (23)
pettit's Avatar
Default RE: Range-testing with DA50
Ignition noise checks should be made at several engine RPM's, idle, mid-speed, and full throttle.
The possible interference may be caused by another problem, vibration.
Old 04-22-2004, 06:59 PM
Geistware
No, just make sure you have it running and the range doesn't get reduced.
Old 04-23-2004, 08:08 AM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
I called DA and they think let the engine run in idle is sufficient.
Old 04-23-2004, 12:12 PM
H. Wayne S
My Feedback: (18)
SORRY, I have to disagree, I have seen RF occur at mid and high range and not show up at idle. I have had it happen to me and I witnessed a pilot coming close to loosing a Patty due to vibration at mid range and not at idle. Muffler bolt-loose muffler pipe- IG box- Spark Plug wire worn and rubbing against the engine- throttle rod- even traced one down to a cracked crystal that would not show it's ugly head until the plane was in the air and the throttle was cut back or wide open.
Better to be safe than sorry and it don't take that much time to check it at all speeds.
My $.02
Old 04-23-2004, 07:14 PM
Forgues Research
My Feedback: (7)
Forgues Research's Avatar
ORIGINAL: Geistware
I respectfully disagree. A bad receiver crystall sometimes will only show up with the higher vibration frequency of a higher throttle setting.
Besides how can it hurt to do a full throttle range check.
Roger
Old 04-24-2004, 11:06 AM
EJB
"SORRY, I have to disagree, I have seen RF occur at mid and high range and not show up at idle."
Yep,I've seen it too.My friend took off & all of the sudden the plane was doing the wildest 3D you've ever seen...OVER THE PITS.Guys didn't know which way to go. Somebody yelled "throttle down!" & he regained control.
