need some advice.
need some advice.
<span style="font-family: Tahoma">i recenlty ugraded my gears on the gear box of my duratax evader st i went from the larger stockspur gear to a slightly smaller( i believe to a 62 tooth) and from the small stock pinion gear to a slarger one and now my notor is heating up and i was wondering if anyone had any recomendations for a better motor to give me more speed and less heat. </span></p>
RE: need some advice.
get a mamba Sidewinder Sv2 for 99.00 motor and esc and you will be very happy it will nice and speedy on 7.2v and super fast a 3 cell lipo 11.1v .it will have no heat problems as long as you dont over gear it . any good brushed motor will cost at least 40 bucks and most likely be to much for you stock esc so just going brushless would be best and cheaper in the long run
http://www3.towerhobbies.com/cgi-bin...?&I=LXAUHR&P=7
is that the cheapest one out there im fairly new to r/c trucks and i dont plan on goin brushless with this truck if ingo brushless im gunna get the slash or the slayer
so there is a price range lol....................
sorry my knowledge of brushed motors is limited since i haven't used one in a long time but i sure someone else will be happy to help you fine one you will like. check your post tomorrow there will be a few people looking to help you this is a very friendly site with many looking to help
good luck :]
good luck :]
haha ya i didnt think it through that much my dad said we could probably find a cheap one around 20 bucks ill keep an eeye on it
the best bet is to put the stock gear back on it for now and save a little 20.00 will not get you a better motor then you have . never buy a used motor always try to get new stuff
you would do better just getting a new stock spur and pinion then getting a new motor for now .at least wait till the stock motor goes out don't worry it wont take long.
i was thinking you could get a slash motor it a 550 size and it would give you a little more speed and could take the new gearing your running and that motor is under 25.00 most likely your best bet on a new motor
http://www3.towerhobbies.com/cgi-bin...&I=LXNMM6&P=ML
ORIGINAL: 378
A 12 turn will fry your ESC.
