TB03 Chassis, Any Good?, What hopups?
I have a TA05. But unless its a perfect track, or indoors, the belts and gears get a hammering.
So im looking at a shaft drive. There are not a lot of reviews about the TB03 chassis yet.
Ill be putting a LRP AI Pro Reverse Brushless ESC and LRP Eraser 9.5 turn brushless motor.
What are the opinions on this chassis. Also what upgrades would I need to handle this brushless system.
I see the TT01 was popular in its day. But from reading the TB03 has already a few hopups out of the box.
Also does it come stock with metal shaft mounts. I read it did somewhere, but the photos and specs dont indicate this.
This would be for racing and drifting.
RE: TB03 Chassis, Any Good?, What hopups?
I hear the TB03 is basically a shaft drive version of the TA05. It also comes with the IFS front end with inboard shocks
So, if you like the TA05 and want a shaft drive I'd say go with the TB03. It's also pretty cheap for what it is I believe
Hi , I got a tb-03 3 month ago and so far I love it. Its my first R/C and I chose the tb over the TT because of the price (got it for 200 $can) and the upgrade part in the tb-03.
The tb-03 have a lot of hop-up and now they got the tb-03D out so we have more part like the spool.
The negative point so far is the steering , the Hole in the link between the steering are too large for the sleeve and that make it a little loose. The tb-03 really need the steering and link upgrade or a least a homemade fix .
The tb-02 have a weak ball diff screw and its break easy but the tb-03 got it fixed (I Broke the plastic frame when I was trying to tight it a little too much but the screw did not break)
OK thanks for the comments.
Group B Monster
Yes I read on another forum the steering was sloppy. But the thread did not advise how to fix it. Will look out for tamiya or 3rd party steering upgrades.
What metal parts come with the TB03 as standard.
I believe it has a metal motor mount. What about drive shaft mounts. Are they metal or plastic.
Will the standard gears handle a brushless system or do they need to be upgraded.
You say the TB03 is pretty cheap. Please explain. They seem to be quite a bit more than the TT01, TB02, or are you comparing to other makes of cars.
Cheers
Group B Monster
Cheers
Hi , the tb-03 do not have a lot of metal part .. tamiya want you to buy them as hop up . the only metal part that come with the kit are the drive shaft , the motor mount . but you can buy some more metal part. so drive shaft mount are plastic but you can buy them in allu if you want. about the standard gear I dont know cause I never use them , I went with aps gear and pinion ( the tb-03 allow many size)
I said its cheap because if you add the basic hop up of the tb-03 on a tt-01 the result will be 80$ + just for the hop up and yout tt-01 will not have all the tuning posibility of the tb-03 .
In my case the tt-01 were around 120 $can and the tb-03 198$ and half the part needed to make the tt-01 a not so bad car were out of stock
the way I fix my steering is a easy one , I remove the link and put some CA glue into the hole where the sleve go , and put the link on a paper , after 2 minute I lift it from the paper to remove the CA glue and that make a ca glue wall around the hole , lets it dry and try to fit the sleeve , repeat if you need more wall tightness. So far this trick hold for 2 month now, but im still buying the steering and carbon link im waiting on them to arrive at our lhs
Group B Monster,
Thanks for the info.
So if I go with the TB03, to improve it to race and handle a brushless system, I should buy the metal motor mounts, the steering and carbon link, and better gears. I will have a look at the ap gears you mentioned. Do you have a link with a part number. I havnt heard of those gears before.
Thanks for the feedback.
Cheers
Cheers
the kit come with a metal motor mount and a 1 piece unit, with greater heat dissipation. you dont need to upgrade it. For the gear I dont know if they good or not with brushless ( I run brush motor) , i saw one guy recommend them over another forum , so I chose them. there some light weight pinion and I got them over there http://www.muchhobby.com/shopping/index.php?cPath=79
if you get a tb-03 I recommend you the carbon and steering, the 2 servo holder in allu (plastic strip easy) and the motor adaptor ((54054) they strip easy too), for the rest its all up to you, also dont tight the diff screw too much or like me you will have to get a allu diff join set for replace the plastic broken one.
OK Thanks.
Yeah it comes with a metal motor mount. I meant metal main shaft mount (to handle brushless) or is the metal shaft mount not required.
Is there anyone running a brushless TB03 can advise.
Ok will also look at "2 servo holder in allu (plastic strip easy) and the motor adaptor (54054)"
So extras are:
Steering and link upgrade
Servo Holder in Alum
Motor Adaptor (54054)
Alum Shaft mounts ???
Gears and Pinions ???
Cheers.
So extras are:
Cheers.
I started a list of hops to the TB03 I was gunna build for TCS when I get the check the president bought our votes with...but at $13 a week it's gunna take a while, lol. I don't know if it's complete or not, so please feel free to fill in any holes I may have missed:
1 RC Pro-Module Rr Susp Set - Fits 415-Evo IV
Item #1004
1 RC TRF Special Damper Set - Hard Black Coating
Item #42102
4 RC 3x32mm Blue Titanium - Turnbuckle Shaft (2 pcs)
Item #42118
1 RC 3x42mm Blue Titanium - Turnbuckle Shaft (2 pcs)
Item #42120
1 RC Wrench for Blue Titanium - Turnbuckle Shaft
Item #42122
2 RC Competition O-Rings - For Oil Dampers
Item #42137
1 RC TA05 Stabilizer Set - Black F/R
Item #49383
1 RC TB03 Titanium Screw Set
Item #49499
1 RC Hi-Torque Servo Saver - Black
Item #51000
2 RC HCCA Differential Ball
Item #53379
1 RC Assy Univ Shaft Cross Joint
Item #53500
1 RC 5mm Aluminum Ball Nut – Blue (standard)
Item #53640
1 RC Aluminum Stabilizer Ends - Blue
Item #53644
1 RC Suspension Ball 8pcs - Fluorine Coated
Item #53709
2 RC Titan Coated 46mm Shaft - 2pcs Stainless
Item #53851
1 RC 5mm Aluminum Short Ball Nut - Blue 10pcs
Item #53869
1 RC Carbon Battery Plate Set - TA05
Item #53884
1 RC Swing Shaft Protector - 4pcs
Item #53890
5 RC 5x5mm Alum Ball Connector - Hex Head
Item #53906
1 RC 5x8mm Alum Ball Connector - Hex Head
Item #53907
1 RC 2.6mm Titanium Sus Shaft - For Reversible Suspension
Item #53917
2 RC Short Reversible Sus Arm
Item #53928
1 RC Aluminum Roll Center Spacer - (0.5mm) 4pcs
Item #53932
2 RC Lightweight Wheel Axle - For Reversible Suspension
Item #53939
1 RC TA05-IFS Rocker Nut - Aluminum
Item #53992
1 RC TA05-IFS Rocker Arm Set - Aluminum
Item #53993
1 RC TA05IFS F Parts - Hub Carrier 4 Degrees, Hard
Item #54031
1 RC TB03 Aluminum Universal - Propeller Shaft Set
Item #54052
1 RC TB03 Aluminum Motor Adaptor
Item #54054
1 RC TB03 Suspension Mount 1XA
Item #54067
2 RC TB03 Suspension Mount 1A
Item #54069
1 RC TB03 Suspension Mount 1D
Item #54072
1 RC TB-03 Ball Head King Pin - (Fluorine Coated)
Item #54075
1 RC 44mm LW Rear Swing Shaft - (Blue)
Item #54077
1 RC Carbon Bumper Support
Item #54089
1 RC 46mm Ltwgt Steering Shaft - (Black)
Item #84007
Item #54089
1 RC TB03 Aluminum Servo Stay - Right
Item #54090
1 RC TB03 Aluminum Servo Stay - Left
Item #54091
1 RC TB03 Aluminum Heat Sink
Item #54093
1 RC Alum Racing Steering Set - TB03
Item #54095
1 RC TB03 Carbon Steering Link
Item #54097
2 RC Carbon Reinforced A Parts - TB03 (Gear Case)
Item #54098
1 RC Carbon Reinforced K Parts - TB03 (Stiffener)
Item #54099
1 RC HT Servo Saver Alum Horn
Item #54121
1 RC TB03 Carbon Damper Stay - Rear
Item #54122
1 RC TB03 Center One-Way Set
Item #54126
1 RC TB03 Reinforced Lower Deck
Item #54147
The lower deck isn't availible yet (at least that's what I'm assuming as TamiyaUSA is out of stock and none of the usual suspects have one either) and no, I likely won't buy everything on this list as it would push past $1000 (with kit, esc and a reciever) just to run it with the silver can in GT3 lol. I just started accumlating a parts list for the heck of it to see where it would lead. But if as you say the belts on the TA05 are that much a pain outdoors, maybe my pipe dream ain't such a bad deal after all...
Cheers,
-M
Item #1004
Item #42102
Item #42118
Item #42120
Item #42122
Item #42137
Item #49383
Item #49499
Item #51000
Item #53379
Item #53500
Item #53640
Item #53644
Item #53709
Item #53851
Item #53869
Item #53884
Item #53890
Item #53906
Item #53907
Item #53917
Item #53928
Item #53932
Item #53939
Item #53992
Item #53993
Item #54031
Item #54052
Item #54054
Item #54067
Item #54069
Item #54072
Item #54075
Item #54077
Item #54089
Item #84007
Item #54089
Item #54090
Item #54091
Item #54093
Item #54095
Item #54097
Item #54098
Item #54099
Item #54121
Item #54122
Item #54126
Item #54147
Cheers,
-M
That car would cost a fortune with all those hopups.
Which ones are really required to handle a brushless system.
The TA05 is a good car even outdoors on a well prepared track. But not unswept parking lots with small stones.
Of course I may be a little jaded...so far I'd say I spent $1500 on my Tiger 1 and haven't seen it move under it's own power yet...lol...but it's getting closer...
The list was just everything I could possibly find (so far) that would be TCS legal...but as no one here in Cali seems to run indoors, the idea of a full boat shaft drive tub chassis "seems" reasonable...
-M
-M
ORIGINAL: Chatty Matty
Item #1004
Item #42102
Item #42118
Item #42120
Item #42122
Item #42137
Item #49383
Item #49499
Item #51000
Item #53379
Item #53500
Item #53640
Item #53644
Item #53709
Item #53851
Item #53869
Item #53884
Item #53890
Item #53906
Item #53907
Item #53917
Item #53928
Item #53932
Item #53939
Item #53992
Item #53993
Item #54031
Item #54052
Item #54054
Item #54067
Item #54069
Item #54072
Item #54075
Item #54077
Item #54089
Item #84007
Item #54089
Item #54090
Item #54091
Item #54093
Item #54095
Item #54097
Item #54098
Item #54099
Item #54121
Item #54122
Item #54126
Item #54147
Cheers,
-M
Item #1004
Item #42102
Item #42118
Item #42120
Item #42122
Item #42137
Item #49383
Item #49499
Item #51000
Item #53379
Item #53500
Item #53640
Item #53644
Item #53709
Item #53851
Item #53869
Item #53884
Item #53890
Item #53906
Item #53907
Item #53917
Item #53928
Item #53932
Item #53939
Item #53992
Item #53993
Item #54031
Item #54052
Item #54054
Item #54067
Item #54069
Item #54072
Item #54075
Item #54077
Item #54089
Item #84007
Item #54089
Item #54090
Item #54091
Item #54093
Item #54095
Item #54097
Item #54098
Item #54099
Item #54121
Item #54122
Item #54126
Item #54147
Cheers,
-M
Out of that very long list, What are REALLY required hopups for racing and to handle brushless and which are more for Bling.
Thats assuming your on a budget and cant buy them all.
Cheers
Ah, shucks, who knows, I'm a noob at the track...my basic theory has always been that if an engineer somewhere was able to convince the bean counters somewhere that a hop-up was economically viable enough go to market, it must be "'necessary", right? All I did was make the list...you'll have to ask smarter people then me which ones give you bang for the buck... my bucks usually seem to go the way of the proverbial drunken sailor and then sit on the shelf after one or two runs...
-M
-M
OK Thanks.
The TB-03 is new so very few have it yet.
Ive asked on the TB02 thread believing they are similar chassis, but there are some big differences. EG engine mount.
However I would imagine many of the parts likely to break on the TB02 would be weak on the TB03.
I only really want to get whats required when I order the kit. Not the bling.
Cheers
Cheers
looking back at the list, yeah, most of it seems to be .01% gain over stock except the steering linkage which everyone seems to think is generally bad, and me personally I'm a fan of carbon reinforced or FRP parts, so for a basic build I'd focus on the steering, A-parts, K-parts, CF damper stays, the rocker arm bits, and the CRF chassis when it comes out...
but then again, I AM a noob...lol...listen to the smarter (more sober) voices out there...
cheers,
-M
cheers,
-M
AB, CANADA
My thoughts now are, if it ain't broke, don't fix it. The only real upgrades I agree with there are the shocks and steering assembly. Other than that it's mostly bling.
I agree druss , if its not broken dont replace it . For the carbon reinforced part A part its the diff case K are the rear tower + motor cover .. I dont see the point to change them if its not broken. these carbon reinforced part are really at the bottom of the list for me.
the only hop up I have on mine so far are:
the DIff joint set ( I broke the plastic one by tightening the diff screw too much, and that why I think tamiya change the diff screw for a better one in the tb-03)
the carbon link + steering ( for fixing the lose in the steering)
the motor mount ( bottom one that slide, mine strip and my brother one too, so I recommend you this one for peace in mind)
the 2 servo holder ( the right one strip for me, If you get them there 2 option for the left one, the standard one and the one for the transpoder if you use it and want to put it there)
the rear propeller shaft ( I got that because im planing to put more power into my chassis and the allu shaft mount look better than plastic one)
The next part im gonna buy :
the spool
the main shaft (to handle more power)
the trf shock
I saw you still asking yourself wich one to get a tb-02 or tb-03
Lets me tell you what the tb-03 got and the tb-02 lack .
The tb-03 got a sloted engine mount that allow many spur and pinion and the mount is really well done with the vent at the bottom, changing the pinion take what 1 min max.
An improve diff screw
you can get a spool ( I saw on a forum that tb-02 owner have a hard way to find one)
MUCH better suspension arm ( tbevo05) reversible with many attach point ( tb-02 got 2 only, tb-03 got 4) to fine tune your car and ready to get a stabilizer bar
the diff cassing of the tb-02 look weak compared to a tb-03 they are really different, look at both pdf you will understand what im talking about , the tb-03 have 3 propeller shaft , and the tb-02 have only one shaft and they really different at the end, Im looking at that right now and by the design im pretty sure the tb-03 can hold more power.
tb-03 got a some nice C hub carrier
and you got some vent under the chassis
So far I really think the tb-03 is really supperior to a tb-02 by design.
Look at both pdf , and both part avaible and make your mind.
the spool
the trf shock
ORIGINAL: Druss
These sound like a good idea,
Alum Racing Steering Set - TB03 #54095 or 3Racing 7075 Steering Racks For Tamiya TB-03
TB03 Aluminum Servo Stay - Left #54091
TB03 Aluminum Servo Stay - Right #54090
TB03 Aluminum Motor Adaptor #54054
HPI M2 x 25 Screws
These are possibles.
TB03 Aluminum Spur Gear Mnt #54094
Aluminum Diff Joints 54056
Heat Sink 54056
Rear propeller shaft ???
The spool ???
The main shaft ???
TRF shock ???
Group B Quote:
Group B,
Thats good rundown of differences for those of us that dont have the TB02 or TB03 yet.
It sounds like for me the TB03 would be the better bet although its a bit pricier at the moment compared to the TB02.
Cheers
ORIGINAL: Group B Monster
the spool
the trf shock
the spool
the trf shock
Group B,
It appears you are the only one on this forum with the new TB-03 Chassis.
Thanks for the rundown of differences.
Thats the sort of info im after.
I think its worth paying the extra for the TB-03 rather than going with the older (and cheaper) TB-02 looking at some of the improvements.
I may order it soon with a fews hopups. Is the 3Racing steering as good as the Tamiya.
Some of the hopups do not fit perfectly.
I had a non Tamiya motor mount in my TA-05. When I put in a LRP brushless recently, the gap between the motor mount screw and main spur gear was uncomfortably close.
I put in the kit motor mount and problem was solved. So the hopup was not really suited for a LRP brushless. Some of the hopups are slightly different fit from the original they are meant to replace. Its just something to be wary of.
Has anyone had problems with the plastic 'Drive Shaft' mounts. (on the TB-02 or TB-03). Would metal one be required for brushless or am I waisting my money.
Hi plane, I think you will not regret it , its a nice chassis and its competitive. About the steering .. I hear on another forum rc-tech i think , that the 3r steering was not very good.. so because I dont want to buy it twice .. I chose the tamiya one.. and corect me if im wrong but I thing Tamiya part > 3racing part.
About the close fit of spur , I dont think you will have a problem, to be sure i just check mine (a 64 picht 96 spur) and the motor mount (plastic stock one, I dont have my 54054 my lhs is pretty slow) you have a good gap you dont have to worry about I try many pinion some really tiny and the gap was OK the spur and the mount are not in line anyway.
Group B,
OK thanks. I will look at the Tamiya Steering.
Ive gone through and selected some of the parts I thought would be good. Its added up to as much as the car (160USD). So i think ill stick with the absolute required for now.
Cheers
Cheers
