mbx pro break problem
when i give my mbx gas it works fine, but when i push the gas it just stalls, i took off the air filter and noticed that when i give it break the carb is all the way closed so this causes it 2 stall, i and many other people have tried adjusting all the little screws on the linkage we cant seem 2 get the break 2 work unless we set the idle so high tat when it closes on the break there is still enough fuel passing through the carb 2 keep it running but that doesnt work becuase the idle is 2 high then, what is my problem and how can i fix it
ps: i have had this car perfectly running for a while then the pull start broke, and it sat for 2 weeks, today i got my starter box and i have this problem it just dont make sence.
