FPV Beginners If you are getting started in FPV this is the place to go for help. Experienced members will help the beginners getting started in FPV, so post your questions you have.
Issues with connection on fpv quadcopter
Old 01-25-2021, 07:34 PM
Kieranj
Default Issues with connection on fpv quadcopter
Hey everyone, so I'm having alot of trouble getting my fpv system, I'm using the diatone roma f5 with the mamba f722 app, as well as a r-xsr paired with the lite radio 2. The problem is that I am not getting any inputs shown in betaflight or on the actual drone itself. to top it off as well there seems to be a connection issue of sorts, it appears that all the inputs are high then they drop for no reason and nothing on the controller was touched ( on the graph at the bottom of the receiver tab on betaflight) . I'm not too sure how to handle this and it's getting to a very frustrating point. Does anyone have any tips or links to YouTube videos or forum's that could possibly help.me out.Thank you in advance
Old 03-10-2021, 03:28 AM
GiantAntCowboy
This response is probably a bit late but here's a check list:
- Is RX bound to the controller and have a solid green light?
- In Betaflight are the Rx settings set to SBUS and Frsky?
- Try moving the controller several feet from the RX/drone when testing. My Frsky RX always have signal breakup when they are close together...
Hope you have it figured out and if so, please let us know the solution. Cheers!
