Rc car drives forward when steered left
I have the electric Kyosho inferno race spec, and today I discovered that when I turn the wheel left, it makes the wheels spin forward, but when I turn right, it's just fine. When I turn it left, it does make the wheels turn to the left, but they also spin like I'm hitting the throttle. Everything else is normal, it drives forward, it stops. Any help here? Also, the throttle is a little jerky, when i first hit the throttle, it takes a second to respond, and its like I can't go at a very low speed, it just jerks and goes a bit faster. and when I do go slow, it cuts in and out like it cant stay steady.
Hi,
Did the transmitter/controller drop and hit the floor/ground lately?
Disconnect the steering servo from the receiver and try it again, twisting the wheel to the left.
If it acts the same then the controller and/or receiver is the issue.
If it acts OK then you have a faulty servo.
Now it only does it when im hitting the gas. let say im holding the throttle down halfway, if I twist the steering knob like im turning left, it speeds it up (only does it sometimes).
