What is the best aftermarket ignition for a G62
My Feedback: (8)
[:@]I'm still having problems with ignition on my G62 is there anybody out there that has a better ignition than what comes on it. There is alot of pilots at our field that has this motor and having no problems I guess mine was built on a Monday morning or Friday afternoon.
RE: What is the best aftermarket ignition for a G62
Recent thread here - http://www.rcuniverse.com/forum/Addi...1205081/tm.htm
As you can see from the pictures, I have all the stock ignition parts lying around since I converted to a CH system. The CH conversion kit is nice stuff. Anyone care to make me a reasonable offer on the stock G-62 ignition? For that matter, what is a reasonable offer for the stock ignition parts, including flywheel/prop hub? It was run, like I think 3 times!
BTW, a nice used CH ignition built into the mount setup for sale here on RCU here - http://www.rcuniverse.com/market/item.cfm?itemId=5801
My Feedback: (119)
PLEASE TAKE MY ADVICE ON THIS ONE!!!!!!!!
Ralph Cunningham (RCING1 here on RCU) I have owned 2 of his conversions and (on my recommendation) another club member sent one in also. Mine picked up RPMs after installation. It is a mechanicial advance which makes it smoother and at $150 installed it is impossible to beat. Combine that with a lifetime garantee and you cannot go wrong. Customer service is UNBEATABLE. Ralph is always at the other end of the keyboard
Let us compare: RC Ignition and CH price arevery close and you have to install the CH yourself
CH warranty is how long? RC Ign is lifetime.
RC Ing picked up RPMs....... Not sure how CH is-- all of my CH ignitions have came installed on the engines
Just my opinion/experience
WY
AJF--2 - unless you don't know, tkg is from CH. This has been discussed here again and again and both tkg and Ralph/RCign1 will tell you there's usually no HP/torque improvement at max RPM unless your timing was off to start with. The advance on magneto ignition installations (if I'm not mistaken) is fixed at the correct setting for max RPM, and as a consequence at all other RPM settings the fixed advance fires too soon resulting in rough midrange and gets progressively worse towards idle. The bottom line is these are both very good ignition systems with lots of positive feedback here on RCU. The only reason I recommended CH is the conversion kit installation is a no brainer - I'm sure performance is similar for both units. Ralph, do you sell a bolt on conversion kit for the G-62? I don't remember ever seeing mention of that here - I realise you'll do the install yourself if it's sent in...
My Feedback: (119)
I do not know all of the tech-no-speak when it comes to engines. I also do not know about timing. What I do know is that on the G62 I sent to Ralph was on a Stinger swinging a Mejslic 23/10 at 6300 RPM-- when I got it back ir was 6500RPMs. The second one was already converted when I got it so I can't say. A club member, Don Weber sent the 62 off of his Nosen p51 and he was using a 22/6-10 and his went to 7600 RPM. He has been using the same size prop for over 10 years and was complaining 2 weeks ago that he was going to have to spend money on another prop. People at the field wanted to know what he did to the plane to make it so lould. I let him use a Menz 22/12 and it knocked it down to 6300 and was a handful in the air until he got some altitude. I am not disputing-- just telling what I have seen-- and as I said
Just my opinion/experience. but I know what I saw
My Feedback: (15)
NC
Now why would a chainsaw ,as they mostly are, be set for max rpm on the mag when its not run as such???.
CH states on their install instructions that the timing can be moved a little and needs to be run and tweaked to get max out of it. (least thats what it says on the last one I got).
I doubt that these beauties are the machined perfection that we wished they were and there has got to be some variations that the fixed timing cannot take care of.
DC
No kits, easier to do it myself...Cut off the crank, make a new carb spacer, put a pressure fitting in the carb and case, set the timing, etc....[8D]
I would just send it to Ralph at RC Ignitions.
http://www.rcignitions.com/
He is a great guy and knows his engines. I needed a six bolt to single bolt adapter for my engine. I sent him some pictures, and he sent me one cool looking adapter that lets me drill one size hole for all my propellers. on all my engines.
ORIGINAL: slojoe
My Feedback: (8)
I didn't mean to start a ignition conflict If the CH is a no brainer I guess I can do it. I really do not want to take motor loose and trust a delievery driver to take it. Had many problems with them. Is there a person in the NC area that can do it?
The CH Electronics Quick Mount is a piece of cake to mount, I have one on my G45 and it was no brainer to install. It does wonders for the idle and starting with the SynchroSpark.
My Feedback: (15)
NC
Remember this is just an opinion....
Ralphs system works great and the extra time and care he puts in his system is well worth the money. I believe his also draws less from the battery pack and he changes the carb mount if needed for a better "shot" at the servo.It is throttle coupled.
CH also works great and is about the same price with Syncro Spark but you gotta do it yourself and it does require a few tools.You get the module and whatever mounts yours requires to fit the sensor plus the hub. It is not throttle coupled.
Feel free to correct me if Im wrong
WY
But all you need is basic hand tools. YOU do have to set the timing to make it perfect. We send degree wheel and instructions with pictures
The QM does not need throttle coupling for timing, thats what the Syncro Spark does, computer timing control. The $124.95 includes the Syncro Spark.
