ChinModel Cessna 337 Skymaster Build
I like to introduce Cessna 337 Skymaster an unassembled scale airplane kit from ChinModel Aircraft, Thailand.
Specifications
- Wingspan: 52 in
- Overall Length: 39 in
- Steerable nose wheel
- Flying Weight: 1820 grams
- Wing Load: 22 oz./sq ft)
- Bolt-on wing mounting
- Building time 60-80 hours
Power and Radio system;
- Brushless Motor BL 2215/1050 KV X 2
- ESC 30 A X 2
- Battery Li-Poly 11.1V 2200 mAh (20C) X 2
- Propeller 9060-1060
- Pusher 9060-1060
- 5 Servos 9 g (Torque 1.8 Kg)
- 1 Servo Hitec 81 ( Elevator )
- Radio 5 C.h. driving 6 Servo (Aileron 2 ) (Ruder 2 )(Elevator 1)(Nose Gear 1)
Specifications
- Wingspan: 52 in
- ESC 30 A X 2
- Pusher 9060-1060
RE: ChinModel Cessna 337 Skymaster Build
Opening the box you will found the following kit package;
1. Fuselage contents pack cut with CNC
2. Boom contents pack cut with CNC
3. Wing contents pack cut with CNC
4. Decals set, molded windshield and windows
5. Hardware contents pack
6. Auto Cad plan sheet size A0 1:1
7. Step-by-step instruction manual CD (over 480 Photo with illustration in Adobe PDF format)
8. 3 sheets of CNC cut parts diagram size A 4
9. Fiberglass cowling
10. Monokote (optional)
Kit contents
Hardware pack includes;
1. Aileron pushrod wire
2. Flexible push rod for Rudder and Elevator
3. Epoxy adhesive Set in 30 minutes and cure in 6-8 Hours
4. Wing strut mounts
5. Wing strut clevis
6. Wing strut dowel
7. Wing strut strap with screw
8. Metal clevis for Rudder and Elevator
9. CA Hinge
10. Control horns
11. Front-Rear motor mounts
12. Sheet metal screw for wing bolt pilot holes
13. M4 wing bolt with plastic washer
14. M4 nut with wood washer for wing bolt doublers
15. 2x6 Sheet metal screw for front-rear cowling
16. Plastic Fin Boom
17. Plastic tab (battery hatch)
18. 2x8 Sheet metal screw for Fin Boom and battery locking tab
19. 1.4x5Sheet metal screw for front windshield
20. 6x370 mm. Aluminum tube for motor mount
Landing gear pack includes;
1. Nose gear set
2. Flexible nose wheel push rod with metal clevis
3. 3 mm. Aluminum main landing gear
4. 55 mm. main wheels
5. 45 mm. nose wheel
6. M3X30 machine screw
7. M4X10 machine screw
8. M4 washer
Decal, windshield and windows
1. Windshield
2. Side windows
3. CESSNA 337 decal
4. DANGER PROP decal
5. Chin Model AirCraft Logo
6. Silver stripe tape
Optional
7. Oracover Film Gray 9 ft
Monokote Film Black 1 ft and Red 0.5 ft
8. FBRPQ decal
9. USAF decal
10. FBRPQ decal
11. Roundel of the USAF (wing)
12. Roundel of the USAF (Fuse sides)
Fiberglass cowling
2 color available
Kit contents
6. Wing strut dowel
9. CA Hinge
10. Control horns
1. Nose gear set
8. M4 washer
1. Windshield
2. Side windows
3. CESSNA 337 decal
Optional
8. FBRPQ decal
9. USAF decal
10. FBRPQ decal
Fiberglass cowling
2 color available
Building Fuselage in brief
- Prepare fuselage parts
- Glue P1 and P3 in position on B1 (Be sure to make a left and right side) then Use F2 - F3 to help you position the P2 and Glue P2, P4 and P8 in place. Repeat steps for the other side
- Join the right fuselage side to the left. Position F5 (servo tray) in place
- Thread pushrod tube through A3, A4 and A5 as position on the plan
- Glue D1 in SF1 and protrudes 6 mm. out of SF1. Position SF1 with F8, sand SF1 to flush with F8 as shown in the photo
- Tape windshield in position, then draw a cut line. Trim windshield along cut line. Re-adjust windshield until it sits well
Building the wing in brief
- Prepare wing parts
- Place S6 in position. makes sure the bottom edge of S6 even with S3
- Trim and sand to shape wing tips as shown in the photo
- Sand dorsal air scoop smooth
- Glue SF3 in position and sand corner round
- Glue WS4 to WS 1. Install aileron servo as shown in the photo
Building the booms in brief
- Prepare the tail boom parts
- Temporarily place BPT1-BPT2 into position. Do not glue them to WP5
- Without gluing, put the Fins into position on the booms
- Glue BPT4 into position as shown in the photo
The manufacturer web site (www.chinmodel.com) is under developing under the name www.thaiscalemodel.com, during this development you can visit our manufacturer web site via www.chinmodel.com/th
Thank you.
Thank you.
My Feedback: (24)
Safe Browsing
Diagnostic page for www.chinmodel.com
What is the current listing status for www.chinmodel.com?
Site is listed as suspicious - visiting this web site may harm your computer.
Part of this site was listed for suspicious activity 2 time(s) over the past 90 days.
What happened when Google visited this site?
Of the 2 pages we tested on the site over the past 90 days, 2 page(s) resulted in malicious software being downloaded and installed without user consent. The last time Google visited this site was on 2009-08-25, and the last time suspicious content was found on this site was on 2009-08-25.
Malicious software is hosted on 1 domain(s), including x1g.in/.
This site was hosted on 1 network(s) including AS4741 (SAMART).
Has this site acted as an intermediary resulting in further distribution of malware?
Over the past 90 days, www.chinmodel.com did not appear to function as an intermediary for the infection of any sites.
Has this site hosted malware?
No, this site has not hosted malicious software over the past 90 days.
How did this happen?
In some cases, third parties can add malicious code to legitimate sites, which would cause us to show the warning message.
Next steps:
Return to the previous page.
If you are the owner of this web site, you can request a review of your site using Google Webmaster Tools. More information about the review process is available in Google's Webmaster Help Center.
Updated 10 hours ago
Next steps:
Thank you for your suggestion, as our web site www.thaiscalemodel.com is underdeveloping to replace the chinmodel website and estimated publish on October 2009. I will let our webmaster to verify the chinmodel website during the new website development.
Nice to see someone still making kits... pity they're all small electrics, not larger glow. Also a pity I'm not still going out with my Thai ex-gf who could translate the website for me. Oh well
Our web site now available in English version www.chinmodel.com/en
I would like to announce the new web site for Chin Model Air Craft, pleast visit us at www.thaiscalemodel.com with English language, community and secure web site.
<span style="color: rgb(0, 0, 128);"><span style="font-size: large;">Cessna 337 Sky Master (GP) Picture More</span></span>
<span style="color: rgb(0, 0, 255);">http://www.thaiscalemodel.com/forum/index.php?topic=20.0</span>
<span style="color: rgb(0, 0, 128);"><span style="font-size: large;">Cessna 337 Sky Master (EP) Picture More</span></span>
<span style="color: rgb(0, 0, 255);">http://www.thaiscalemodel.com/forum/index.php?topic=4.0</span>
<span style="color: rgb(0, 0, 128);"><span style="font-size: large;"> Slide show </span></span><span style="color: rgb(0, 0, 128);"><span style="font-size: large;">Cessna 337 build the fuselage</span></span>
[youtube]http://www.youtube.com/watch?v=DL3p7VlsDFE[/youtube]
<span style="color: rgb(153, 51, 0);"> <u><span style="font-size: x-large;">New Product</span></u></span><span style="color: rgb(0, 0, 255);"><span style="font-size: x-large;">
<u>Super Ultralight Thailand</u> </span></span><span style="font-size: medium;">
</span><span style="color: rgb(153, 51, 0);"><u><span style="font-size: medium;">Unassembled scale airplane kit </span></u></span>
Specifications
- Wingspan: 53 in
- Overall Length: 42 in
- Flying Weight: 1720 grams
- Wing Load: 19oz./sq ft)
- Engine .25-.35
- Building time 80 hours
<span style="color: rgb(0, 0, 255);"><span style="font-size: large;">
<span style="color: rgb(0, 0, 0);"><span style="font-size: medium;">
<span style="color: rgb(128, 0, 0);"><u><span style="font-size: large;">More </span></u></span></span></span></span></span><span style="color: rgb(0, 0, 255);"><span style="font-size: large;"><span style="color: rgb(0, 0, 0);"><span style="font-size: medium;"><span style="color: rgb(128, 0, 0);"><u><span style="font-size: large;">picture</span></u></span></span></span></span></span><span style="color: rgb(0, 0, 255);"><span style="font-size: large;"><span style="color: rgb(0, 0, 0);"><span style="font-size: medium;">
http://www.thaiscalemodel.com/forum/...php?topic=27.0
[youtube]http://www.youtube.com/watch?v=ObX_q2GDDSY[/youtube]
</span></span>
</span></span>
hello,
we have bought a ESM Cessna sky master http://www.modelflight.com.au/rc_mod..._skymaster.htm. Un fortunately could not have the instructions manual and so no idea of its CG! Can anyone please guide us about its CG?
Thanks!
Haisan.
Thanks!
Haisan.
Hi haisan,
Apologize for the delayed response.
C.G. on position make nose heavy 5-7 degree
<span id="result_box" class="short_text"><span style="background-color: rgb(255, 255, 255);" title="นับถืà¸*">Regards.
Chinnathon A.
</span></span>
Chinnathon A.
</span></span>
