SV 26CC NO MANUAL
CO
SV 26CC NO MANUAL
Hello,
I just purchased a SV26 cc from Hobbycity. It didn't come with a manual. It also appears that there are no manuals online. I know how to set up the engine but need the information on oil to fuel mixing ratios. Like 1:30.... What is the proper break and running ratios. What gas do you use (93%) and what oil seem to work best. What spark plug are you guys using? Also what are some of the prop sizes. Does anyone run 3-bladed props? If anyone could give me some info and some personal experiences with this engine I would greatly appriciate it. I am putting this motor in my new Showtime 90. It's going to be nuts....I hope.
MGTECH
MGTECH
My Feedback: (221)
RE: SV 26CC NO MANUAL
Go to RC Showcase. They sell the same engine and do have tech info for it including prop recommendations. I am running reg gas and 30-1 Lawn Boy for break in, with an 18 X 8 prop. It is a sweet engine. DO NOT USE HIGH OCTANE GAS. These engines are not high enough compression to benefit from it. They will just run hotter. I used the supplied spark plug and it works fine, no RF. The ignition is shielded and grounded.
