wheels will not turn
SC
i tried every thing. the wheels of my nitro quake wheel drive truck will not turn. if you pick the front end of the truck up they willturn and good. here are the thing i tyried 4 aa bateries, 6 batteries, and a 9.6 volt baterie.all a diff times. i do not know what is wrong. maybe 2 steering servos?? please help
RE: wheels will not turn
JUST GO OUT SIDE AND PUSH THE TRUCK ONE GOOD TIME DOWN THE ROAD AND TRY TO STEER IT WHILE IT'S MOVING . I BET THEY WAN'T . I BET IT'S THE SERVO .
when you pick up the front and turn listen to see if there is a faint clicking noise, it might be stripped gears in the servo. (had that happen to me[:@])
Another possibility could be that the nut/screw on the steering linkage is too tight. If you over tighten this area the wheels won't turn left or right.
SC
i tyied every one of those thing nothing working. it is makeing a nose when you hold it up and turn the whells?? we going to buy a hole new servos. maybe that well help.
