Wren 44 Heli V 50i heli engine diferences
I have owned a Wren 44 heli engine for a number of years now. It has operated perfectly. I purchased a Wren 50i engine just before they went into liquidation recently. It is not a happy engine - neither am I.
Does any one know what the differences are between the 2 engines?
My reason for asking is that my 50i is very prone to 'compressor stall?' accelerating at the lower end (1/3) of the RPM range (as you would expect). Evidenced by blue flame exiting the exhaust with a loud roaring sound - Ng decreases. Acceleration delay is now 80. The engine operates perfectly once it is above ~1/2 power.
By chance today I discovered that the problem wouldn't occur if I flew my MD500 without the front canopy fitted. Lots of cool air to the engine. If I fit the canopy - problems. I have operated this body for years with the wren 44 without issue. All of the side door windows are open, and the exhausts exit the fuselage through short extensions. Could the 'compressor stalling?' be caused by warm(er) air from the engine entering the engine inlet??
I would appreciate any advice.
Cheers
Craig
in warm Adelaide SA
Cheers
Craig
in warm Adelaide SA
As bad as it sounds but you have to raise the delay. The wrens often shoot blue flames and if they do, you only can raise delay. There won't be flames no more. Don't ask me why, even Mike Murphy couldn't help then.
Cheers
Craig
in warm Adelaide SA
Cheers
Craig
in warm Adelaide SA
