pull start troubles...how do i put it back together?
hey how would i put a pull start back together it just sprung open(but i did unscrew the back of the stock p/s)but could someone please let me know how to do this or if there is like a diagram i'am very confused lol so please just tell me what to do
All ive heard that it is really really REALLY hard to put them back togeather... You should probably go buy a new one i think they are like $10.00 but you should check on towerhobbies.com to get a general idea of how much they are.
well the problem is that i have a mad force with a gs engine and my lhs doesn't support the mad force so i have to put it back together other wise i have to order from the net
i will try to get a diagram for you but in the mean time go to www.towerhobbies.com and check one out it might be better to buy one
here is a link on how to do it on a ofna car but i think most all the pull starters work the same way so here is the link and good luck www.angelfire.com/ks/NitroRS4/Pull.html
re-coil rebuild
hi shades saw ur problem & been there myself, that link that Drager gave you should have helped ya, another tip is that if the coil hasn't come apart or if u got to re-rap it tie it up in afew different spots with some sewing thread it's easy to cut & remove after you put it back into the housing i'de also get a spare new starter & keep it in your field bag, it's saved me in the past.
