how do i get my wheel off
RE: how do i get my wheel off
you could try taking the remote apart and looking for a screw to take the wheel off. if this works and you can put a different wheel on then make sure your springs are set right and also the steering.
i already took it apart and the peice that holds the wheel on is not screwed on and when i tryed to take it of with a plyers the plastic peice broke, it wasnt a big deal but i didnt want to go any further without some other input on it. thanx
On the center of the wheel, there is a stick on sticker (should be metal the size of a dime). Pry it out and it will expose a screw. This screw is what is holding the wheel from the adapter.
