MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVS 58 problems
Old 11-28-2006, 03:26 PM
leo3d
Default MVVS 58 problems
The engine is brand new, I've only tested one day but I've found this problems:
1- The engine won't start, when I put choke on fuel flow out from carb but there is no fuel going to the spark.
2- When I tested the spark with the engine's chassis I realized that there where only one spark. But there are two magnets on the engine crank. What's happening? Is it normal???
3- When the engine idles at 2500 rpm the engine stopped. It's happening two times. Is it a spark plug problem??? or may be the electronic ignition system???
4- When the engine is hot it doesn't start. Why???
I'll put this message in my original language if there are any doubts on the setting.
el problema es el siguiente
1º el motor le cuesta mucho arrancar, si lo sebo cdo habro el sebador sale combustible pero en la bujÃ*a no parese llegarle tanto combustible
2º cdo probe la chispa, en el sigueñal hay 2 iman para el encendido, ¿Es normal que solo genere la chispa en 1 solo de los imanes?
3º con un ralenti alto en 2 oportunidades se paro el motor (2500rpm aprox), es problema de bujÃ*a o de encendido?
4º el motor en caliente no arranca, por que?
Old 11-28-2006, 06:46 PM
pe reivers
Default RE: MVVS 58 problems
This seems a carb setup problem (lean idle, leak in pulse lines or fuel lines, or no pumping). Did you connect the lines well? (photo's please)
The top magnet fires the ignition, the second magnet does not fire, but resets the ignition ready for the next spark.
Is the battery Voltage you use OK?
ICU ignition needs 6 cells or two LiPo (pro needs 3 LiPo)
Vlach needs 4 cells, but sometimes 5 cells is better. (Vlach <must> have resistor type sparkplugs)
Old 11-29-2006, 04:54 PM
leo3d
Well I have the 4,8 volt ignition system, and I'm using it with 4,8 V too. And the sparkplug is resistor type.
These are the pics of the fuel lines.
ID:	568895   Click image for larger version
ID:	568896   Click image for larger version
ID:	568897   Click image for larger version
ID:	568898   Click image for larger version
Old 11-29-2006, 06:30 PM
pe reivers
Just a few suggestions:
- rotate the pulse line elbow nipple (foto 1) straight towards the engine and make the pulse line as short as possible. Use clamps on the line ends. They may leak when the engine gets warm.
- clean the internal fuel strainer inside the carb.
- get rid of the T-charge valve in the fuel line (drawing). This may be a cause of problems if it leaks air.
- clean the carb inside very well. Do that again, and again, and again.
I like to try a replacement carb. If that makes the problem go away, the carb is at fault.
Old 11-30-2006, 06:20 AM
BaldEagel
BaldEagel's Avatar
Leo3D
Do everything Pe has advised plus try the engine with a 6 volt supply i.e. 5 cells this may be all you need.
Mike
Old 07-21-2018, 06:21 PM
Vandrezambon
Default Have you solve the problem?
Hi,
I'm having the exactly same problem, did you solved it? How?
thanks
