Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
What Can/Should i do with this? (Noob)
Old 07-02-2011, 08:48 PM
Martellus
Default What Can/Should i do with this? (Noob)
So a few months ago Ibought this rc car off a guy, and i was wondering what to do with it, since it has no engine muffler etc. I dont even know what to call it, truggy? car? something else? I would like to get it working, and any sugg. Itsprobably a POSto most of you guys, but it would be nice if you could help meatleastknow my options. All the servos and everything else works to my knowledge.Thanks for any help ahead of time!</p>
Old 07-02-2011, 09:36 PM
BKoz559
BKoz559's Avatar
Default RE: What Can/Should i do with this? (Noob)
May we see an example of this vehicle so we can see what you're referring to?
Otherwise, whatever you do is fine by me.
Old 07-03-2011, 06:39 AM
FahrtAutoRC
FahrtAutoRC's Avatar
Yes, you cannot be helped unless the people helping know what they are helping with haha
Old 07-03-2011, 06:54 AM
i8tweety
i8tweety's Avatar
I pulled this from his photo gallery. I trust it is the one.
Old 07-03-2011, 09:17 AM
Martellus
That is the one. I guess Ididnt finish attaching the photos correctly.
Old 07-03-2011, 11:27 AM
378's Avatar
Looks to me that it, obviously, needs an engine and exhaust system. It probably also needs motor mounts, flywheel and clutch. Shouldn't be hard to get running, but an engine can run from 90 to 250 bucks depending on what size and the quality.
Old 07-03-2011, 06:07 PM
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
Give it to electricrc68 so he can douse it in nitro and set it on fire.
Or he can give you his fuel so you can douse it in nitro and set it on fire.
It's a HiSpeed Model manufactured buggy, not particularly good, but if you can score a decent used engine for cheap (OS .15CV-X, or the Dynamite Mach 12 pullstart is under 100 bucks new.) and get some help tuning, you can snag an HPI header for the RS4-3 and an Associated pipe, and have the car running better than that car would be if it was new for about 150-175 total.
http://www.horizonhobby.com/Products...ProdID=DYN6511
Old 07-03-2011, 07:44 PM
Martellus
ORIGINAL: ThunderbirdJunkie
.... Thanks but no thanks
[/quote]
[/quote]
Awesome! Didnt expect it to be top of the line haha
[/quote]
[/quote]
awesome, but what is an HPIheader? or an RS4-3? im guessing the associated pipe is the muffler.
Old 07-03-2011, 08:22 PM
ThunderbirdJunkie
HPI is a manufacturer, RS4-3 is the model that they make, the header is the part that bolts to the engine to direct exhaust into the exhaust pipe (the Associated (brand) pipe)
Old 07-03-2011, 10:11 PM
378's Avatar
I assume, TBJ, that by Associated pipe you mean the stock pipe that came with my car, right?
Old 07-03-2011, 10:23 PM
ThunderbirdJunkie
That would work, but ThunderbirdJunkie just means any of Associated's pipes that came with any of their cars. The smoothie that came with the GT2 FT, the torque-tuned dual chamber that came with yours and ThunderbirdJunkie's NTC3's (which sounds WICKED paired with a high-revving side-exhaust 12), really any of them. In this case, the dual chamber torque-tuned NTC3 pipe is probably the way to go.
Old 07-03-2011, 10:27 PM
378's Avatar
They sound sweet even with a lazy low-revving .18, and they certainly do boost torque significantly. When I bought one and installed it on my monster truck it made the difference between one that will do gentle takeoffs when you jam the throttle wide open and one that will carve donuts on command
Old 07-07-2011, 07:07 AM
Martellus
Thanks for the info guys, i will keep it in mind.
and 378? It seems I am not the only spy....
Old 07-07-2011, 07:28 AM
electricrc68
Banned
LOL sure i will do that. maybe add some explosives for added effects.
<br type="_moz" />
Old 07-07-2011, 07:45 AM
proanti1
proanti1's Avatar
No, you cant use an Associated pipe because the pressure fitting/hole will be on the bottom.
You can get one of these cheap shuwa/toki engines, which are actually pretty reliable when it comes to RTR. http://cgi.ebay.com/Toki-18-Theaded-...item2eb6014596
Then get this http://cgi.ebay.com/Exhaust-Manifold...item2311154a1e
Then this http://cgi.ebay.com/HPI-A868-Tuned-P...item3cb7e25691
And these should also work http://cgi.ebay.com/Redcat-Tornado-S...item2eb65a2260
Of course you will still need a clutch, exhaust gasket, silicone coupler, some throttle linkage, and some hardware... but this stuff will take care of the basics.
Old 07-07-2011, 09:52 AM
ThunderbirdJunkie
Huh?
http://www3.towerhobbies.com/cgi-bin...?&I=LXCKN4&P=7
ITBJRC only the Smoothie pipe has the pressure fitting on top.
Old 07-07-2011, 12:11 PM
proanti1
proanti1's Avatar
Oh, well I stand corrected. I have a big box of associated pipes too. I honestly wouldn't spend $30 on a pipe for that car though...
ITBJRC?
Old 07-07-2011, 12:14 PM
electricrc68
Banned
i think ITBJRC stands for:<div>
</div><div>In Thunderbirdjunkie's RC?</div>
Old 07-07-2011, 12:21 PM
378's Avatar
Huh?
lol both of mine are natural aluminum colored.
Old 07-07-2011, 05:55 PM
ThunderbirdJunkie
ORIGINAL: electricrc68
If ThunderbirdJunkie Recalls Correctly[&:]
Old 07-07-2011, 06:05 PM
electricrc68
Banned
i got the thunderbirdjunkie part right.
