Glow Plugs Die After Few Starts
why o why do my glo plugs give out..the coil is ripped after like 3 starts? is it my fuel? i use wildcat eliminator. I just got a new fantom too! bah?! ive used dynasports, Mcoy's, traxxas. everytthing..what should i do..?
i've had the same problem with breakin. lower you nitro to 10% or add a shim. the excesive compression has something to do with it. after breakin it should be normal. unless your rod bushing is coming apart! then you phuqued
