piston screw
WI
piston screw
how do you remove it? when i use my hex it just spins and doesent come out
i know its not striped cause ive never taken it out befor
RE: piston screw
I have never seen one with a screw, allen, recess bolt, anything like that in it.
Most likely is it just a smooth pin with two C clips, one on each side. You remove the C clips and you will be able to just push it out. What type of motor is this?
PA
RE: piston screw
HAHAHA Sorry just had to have a quicke little laugh there, it's not a screw so thats why it not coming out. If you look at the wrist pin (what you called the screw) there will be a small c clip holding that wrist pin in. You will need a small needle nose or small flat head screw driver to get it out. As soon as you get the clip out the can just push the pin out fron the other side. It should come out pretty easy
