zenoaoh G-38
Old 12-04-2005, 07:16 PM
rthalls
My Feedback: (63)
Default zenoaoh G-38
will a G-38 fly a Mister Mulligan 108 WS that will come in around 23 lbs ??? if so what size prop would you use .........thanks
Old 12-04-2005, 07:56 PM
captinjohn
Default RE: zenoaoh G-38
Try a 18x10-6 [:-]
Old 02-05-2008, 11:22 AM
tony0707
hi 23 lbs is too much weight-for the g-38-to pull with any authority-- the 18/6-10- i think is the prop to use--or an 18/8--both were zingers===tony==
Old 02-05-2008, 12:49 PM
bhole74
bhole74's Avatar
My G-38 hauls my 25 pound D-7 just fine with a 20x8 MAS Scimitar.
Old 02-05-2008, 03:01 PM
Jburry
Jburry's Avatar
This really depends on your flying style. With an 18x8, the '38 will make about 17 pounds of thrust (static). That'll make a pretty marginal aerobat, but for a put-along, it'll work just fine!
What do you want your plane to do? She was supposed to be a racer, and in level flight it should be pretty well motivated. Not real quick, tho, with the 18x8, you're looking at flight speeds in the 50-60mph range.
More pitch will give better flight speed, but at the expense of thrust.
Pretty model, that!
J
Old 02-05-2008, 04:48 PM
the Wasp
I had a G38, I think you would be better-off with a lighter more powerful 40cc or 45cc
Jim
