Glow plug a day
Old 06-04-2010, 07:31 PM
JH313
Default Glow plug a day
I have a stock Nitro Stampede with a nitro sport header and exhaust pipe. The truck works great except after every run i have to replace the glow plug with a new one.
I bash in my front yard, starting with a full tank and running to empty. I then put it in my garage for the night and the next time i try to run it, the glow plug light doesn't light. This happened last season even with the stock exhaust.
Any help would be appreciated.
I use the super duty plugs which run at $8 a pop. Way too much for 15 minutes
Old 06-04-2010, 07:36 PM
thechap76
My Feedback: (26)
Default RE: Glow plug a day
is it a new engine....still underbreak in period???? does it give off a good stream ofsmoke while its runnin ????
Old 06-04-2010, 07:37 PM
dug44
So you run the truck till it dies (completely out of fuel)?
Old 06-05-2010, 09:22 AM
JH313
It is way over break-in and yes i do run it until it is out of gas.
I run very rich so that it creates a large amount of smoke.
Richer than factory settings
Old 06-05-2010, 09:46 AM
mmtecg
You should lean it out. That might be way your going through glow plugs so fast!!!
Old 06-05-2010, 10:50 AM
bao
Theres no need to run it too rich , running too rich or too lean is a sure fire way to go through glow plugs . i would imagine your blown plugs are dark and oily . running an engine too rich is not good for the engine either as un burnt fuel deposits will also effect the performance.
Old 06-05-2010, 11:00 AM
only1battman
only1battman's Avatar
Just kinda curious.
how long can a glow plug last, mine just went out on my 3.3 yesterday.
it was no big deal i always have spares.
Old 06-05-2010, 11:21 AM
mmtecg
ONLY1BATTMAN
How many trucks do you have? And what kind are they.
Old 06-05-2010, 01:19 PM
only1battman
umm i have mostly have electric and 1 nitro
Nitro: Revo 3.3
Electric: Slash, Blackfoot Xtreme, Traxxas Sledgehammer, Tamiya Superhornet, and some REALLY REALLY old Asscociated RC10Ts.
its fine just curious why you want to know??
Old 06-05-2010, 02:05 PM
mmtecg
What kind of slash? 2x2 4x4???
Old 06-05-2010, 06:20 PM
dug44
ORIGINAL: JH313
I would tear down the engine, and clean it well. Put the needle's back to factory settings (that's plenty rich). And STOP running the thing till it's empty... Your going from a super rich engine to a super lean engine in about ohhh, seconds...
Why run it rich? That as well as running lean, takes a toll on the engine. Not too mention greatly reduces the life....
Old 06-05-2010, 09:04 PM
JH313
When they suggest to turn it off by pinching the needle, isn't that the same thing?
It is written in the manual to turn it off that way.
It doesn't slowly lean out either.
Old 06-05-2010, 09:43 PM
dug44
ORIGINAL: JH313
The first thing i do is take that red "pincher" off. Worst way to shut it off, IMO. I block the stinger (outlet on the exhaust). Or the best way "they say" is to chock the flywheel. Stop the engine at the flywheel... Dynamite (engine manufacturer), recommends to chock the flywheel.
Don't get angry man, just my suggestion... I have had the same glow plug in my MAXX and my JATO for about ohhh, a month (atleast)... The only reason I had to change my plug in the REVO was a tuning issue... My bad on that one. Thanks to SNOOk, it's all set now.
Old 06-05-2010, 10:11 PM
JH313
I wasn't mad, I was just explaining why I do it the way i do. I will take your advice though.
Are there any other glow plugs that work with EasyStart besides the traxxas ones?
Once tried a third party except the wire wouldn't fit.
Thanks for your advice
Old 06-05-2010, 10:19 PM
dug44
The o.s. 8 will work. You just have to spread the spring a little bit.
I take off the blue ignitor wire and use a glow ignitor, saves my starter battery...
