GP Fling Bungee launch? Buy from?
MS
I got a GP Fling from a local RC auction and want to bungee launch it, but am not sure which bungee I should use.... full size or some other smaller size, and then where can I get the launcher from?
RE: GP Fling Bungee launch? Buy from?
Is this the small Fling or the 2 meter Fling?
The small came with a mini hi-start i the original kit box for the plane. The Fling 2 meter would use a standard hi-start as listed in Tower Hobbies.
http://www3.towerhobbies.com/cgi-bin...?&I=LXYXK6&P=7
Sure some of the others will chime in here too. You can also check the buy and sell.
Sure somebody would have one they are not using.
tink
tink
Tink's recommendation will work but it is the shorter upstart, not the full length highstart. I've used it and it works very well on the smaller regular Fling. You can also get the tiny one included with the Fling but the one below will get you way up there.
http://www3.towerhobbies.com/cgi-bin...?&I=LXYXK4&P=7
