airbubbles in fuel line
when i give full throttle on my nitro 15fe i can see air bubbles going up the fuel line to the carb and the motor bogs down after two seconds at full throttle ,the fuel tank is 1/4 to full and it does it whether or not the car is driving on the ground or on a stand
(off the ground) . is this normal?
fuel lines would be the 1st place to start, also, vibration might be making your fuel foam when it gets low. Put some o-rings on the tank mounts to lessen the vibration, just don't tighten them too tight.
