whats wrong?
Old 02-27-2006, 02:40 PM
nikdanfinn
Default whats wrong?
hi, when i pull the pull start the wheels turn, does this mean i need a new one way clutch bearing? i replaced it a while ago and it was not turning the engine, is this something else?
Old 02-27-2006, 03:03 PM
mgtman
Default RE: whats wrong?
ORIGINAL: nikdanfinn
sounds like you are right you might need a new clutchbell bearing again[:@]
Old 02-27-2006, 03:09 PM
snowbl!nd
snowbl!nd's Avatar
Either that or the clutch spring is damaged and constantly engaging the clutch.
Old 02-27-2006, 03:17 PM
nikdanfinn
hi, i just took it apart and the bearing seem fine, locking 1 way ect. how di i find out if its the spring?
thanks, if it was not for your knowledge i would never have it running!!!
Old 02-27-2006, 04:15 PM
Dawman
My Feedback: (33)
check your springs for tension , one might have a lot less tension than the other. Or a broken spring.
