webra bully 35 ignition
My Feedback: (9)
PA
hello, any body have or know someone who has the ignition module for the old webra bully 35 gasser? or has used a different module adapted to it? any info would be a help. thanks guys.
RE: webra bully 35 ignition
I converted my old glow Bully to gas utilizing an Rcexl ignition.
It does take a bit of work as you have to drill and tap the housing for the pickup, and install a magnet in the propeller hub, but it´s not all that hard. Of course you will need the appropriate tools, pillar drill, taps and so on.
If the original ignition was a CH or CH type ignition you might find what you are looking for here.
http://www.rcextremepower.net/ignitions.html
Milton
Milton
I would try RC ignitions. I have bought from them and they are very reliable and very reasonably priced. Ralph the owner is a store house of knowledge and will share it on his forums.
http://rcignitions.com/index.php
Good luck
Gary
Good luck
Gary
ORIGINAL: KenLambert
I am in the process of making the parts for a bolt on kit for the conversion to use the rc exell ign plus walbro adapter for the glow carbs
Capt,n
