belt cp servo question
NY
i crashed my belt cp and had to install a new pitch servo.Before fully installing it i plug it in and it went all the way to the left and then kept vibrating.I tried that a couple of times but don't want to burn it out.There is no response when i give it throttle.Any ideas? Also it is an esky servo.
RE: belt cp servo question
Most probably you got either a fake or a bad one. Most, if not all, Esky servos sold at ebay are fake and bad quality.
Just plug one of the other servos you have in this channel to the receiver and see if the receiver is not damaged.
If it is not, which it must not be, then you definitely got a fake or bad one.
Moderator
Even if it's a real Esky servo, they aren't that good to start with. If you'll put a few dollars into better servos it makes a big difference in how well the machine flies, at least in mine it did.
