Peak 26cc muffler option?
MI
hello all...I have a Peak26cc engine that came with the pitts muffler but it was welded crooked...instead of parallel with the engine fins it was slanted up about 30 degrees. To cut the engine box/firewall was not an option because it would have been too weak (rear carb inside engine box) so I cut it and tried sleveing it with JB weld etc and you probably know the rest...leaks black goo all over etc. Has anyone found a muffler off a different motor that works on the SPE or Peak 26cc gasser? doesn't have to be a pitts either, inverted style would also work. I called Peak and Cermark but they dont have parts for these motors yet. I dont like waiting to fly my plane untill parts become available. Thanks alot!!
Ron
Ron
