Walbro Carb Question(s)
My Feedback: (131)
TN
I've got several WT-349 carbs that just die rather than pick up and run when they go to WOT. It makes no difference how far you crank out the hi needle. I even got some weak needle/seat springs from Scott Brilleli, but no luck. Ive tried these on 25 and 35cc engines, no difference. I hate to throw them away, I've maxed my skill level out at this point.
Ive also got a couple that flood. After you prime them ,they just continue to fill with gas, not good. ANy ideas on what the problem is here? Thanks, flyrc100
RE: Walbro Carb Question(s)
if you see almost no effect after opening both needles, you may have dirt somewhere, start removing the needles and clean them up (the seats too)
