Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
3GX setup problem
T-Rex heli For all you T-Rex lovers out there, this where you can post!
3GX setup problem
Old 12-14-2013, 08:31 AM
F106A
F106A's Avatar
Default 3GX setup problem
Hi,
I have a 450 Dominator and can't get the 3GX working correctly.
The problem is, when I move the throttle the 3 other servo's move. The throttle does control the motor.
I've gone over the wiring and it's correct according to the manual.
Any help will be appreciated.
Jon
Old 12-20-2013, 06:29 PM
RCSCALEGUY
Check out 3gx dir process by Jeff Fassbinder on youtube. Make sure dir is set correctly. All servos should move when throttle is moved, pitch requires ail, elev, pit. Nose facing forward check ail, pit orientation. Check manual again.
Old 07-17-2014, 10:49 AM
dchin62973
3GX SETUP(for V2.0、V2.1、V3.0 and V3.1)
http://youtu.be/W4EANApW07g Above is the Align 3GX Setup.
