Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Dx6i radio set up help
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 04-10-2014, 05:57 PM
gabbyb3
Default Dx6i radio set up help
Hi, in need of help setting up my radio for a trex i just gott. Also was wondering about setting blade pitch for hovering, as i have not flown a heli in a while ..
Old 06-22-2014, 08:47 AM
madmorgan
all the pitch info should be in the size trex manual your setting up google say trex 450 manual if its a 450 you have 500 etc etc then all you do is light up heli with motor unplugged check the pitch at low mid and high pitch ranges i think 450 is usually between 2-5 degree on low in normal mid stick 0-+2 and high +9-12 idle up -9-12 low +9-12 high .
Old 07-04-2014, 09:50 PM
R.C.Man
I set mid stick for 0 pitch (50% on the Dx6i)in the menu, If your using normal flight mode (no Idle up) set your pitch curve for -2deg to 0deg till mid stick, than 75, 100%
Throttle curve for a easy flight, 75% from 50% pitch. Or your likings for headspeed. 0,25,75,75,75%
Good Luck man.
