P180 rx error on power on
Hi All
My P180 that was starting reliably after many starts, but has started failing on start-up., at various points wil low RPM error so just working through the issue
but I am also getting an issue at power on..
Initially it recognises the Turbine type 'Digital power bus P180 RX Rdy' then 2 seconds later gives an error, ' Eng Unknown connected V7.7,
any one else seen this isssue or thoughs?
thanks
Simon
thanks
Simon
thanks Dave
So Removed from aircraft onto the test stand different receiver and throttle lead, relearn...
Check same failure Yes
Clean all connectors etc and First increased to 0.12 and then 0.150... both fail to start... Low rpm
Limited Telemetry through a Xicoy FC...for some reason Pump is not reporting via FC... But is running and starting to ramp up when error occurs.
All failed starts seem to not be able to get passed about 5K on the RPM/EGT 190 before error occurs.
Have a plot but cannot upload at the moment due to limited posts!
thanks deg
Simon
thanks deg
Simon
Can you run the pump on the GSU test function? Change Value and +/- to go up and down voltage from 0.5v. It should follow freely and pump good fuel up to 4.0v
Ok so no luck, still low RPM, fuel is increasing as more flame being generated
Starter does not seem to start the ramp up beyond the 4-5K... is there any way to check the starter
thanks
Simon
thanks
Simon
