What size engine?----Servo size--Wife say's no
Old 07-19-2002, 05:18 AM
beep
My Feedback: (49)
Default What size engine?----Servo size--Wife say's no
I'm building three cropduster type aircraft. All will dust or spray, but the one i'm concerned about is the 1/4 scale AG-WAGON, THAT WILL HOLD UP TO 31/2 GALLON'S of colored water. Empty weight 28# a 10' 8'' wingspan. i've have FOUR engines to pick from---A SACH'S 5.8------QUADRA 75----BRISON 4.2 TWIN AND A BRISON 6.4 Twin. My takeoff weight could possibly be 48 to 58#. NOW I'M NOT GOING TO BE DOING NOTHING FANCY, SIMPLY FLYING SCALE and of course with flaps down, probably 15 degrees. My servo selection, Airerons 2 futaba 9201 69.7 oz in- at 4.8 volts one for each---rudder and elevator 1 on each futaba 9201 mounted in the back---- FLAP'S Futaba 1 ea. S3302 with metal gear's-----throttle & switch for 12 volt rv pump will be futaba 148. Is this a gray area. I plan on going to a 6 volt system, how much more torque will i get? And the last and most important question, MY WIFE a freshman high-school sweet heart say's no water and is a little hot over it, Should i spray and cool her off?
Old 07-19-2002, 01:59 PM
skymat
OK , you do not work for OSAMA BIN LADEN do you?
Old 07-19-2002, 02:48 PM
tinman
My Feedback: (13)
Default .
i was wondering myself.....
Old 07-19-2002, 02:58 PM
MinnFlyer
MinnFlyer's Avatar
And I hope I am correct in assuming that you have KNOWN your wife since she was a freshman in High School, and not that you're married to a 13 year old!
Old 07-19-2002, 08:48 PM
Traxxas_Tech
My Feedback: (22)
Traxxas_Tech's Avatar
Me too
BTW what was this post about?!?
Old 07-20-2002, 10:23 AM
stomper
My Feedback: (20)
I think he wants to know if he can take off with some twenty pounds of colored water ?????
I just love R/C
Old 07-20-2002, 03:19 PM
Carlos Murphy
My Feedback: (72)
Default Washing all the cars in the parking lot?
Take off weight? Just don't use "heavy water".
Old 07-21-2002, 06:44 PM
Robby
My Feedback: (18)
Ok,, Had damn well better listen to Carlos... 'Cause we -ALL-
know what happens when Murphy's Laws are enacted...
Robby <srry, Carlos,, I just couldn't resist>
Old 07-21-2002, 07:26 PM
Geistware
At about 10 lbs a gallon, 3.5 gallons is 35lbs. With another 28lbs in plane and another 1.5lbs in gas (32oz tank) you gross weight could approach 65lbs. I would check your wing loading and if you are under 50oz/sqft then you should be able to take off but not do much until you dump that water. I would have a backup control because I would not want to land with that much weight!
Old 07-21-2002, 07:56 PM
3D_CAP232
Default Servo Torque at 6v
Last time i contacted Futaba about this they reckoned on adding 15% for torque at 6V.
